diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Someone with LEAP please enter - Click HERE for Original Thread
ocaukrell
I have a pair of Nakamichi SP80 bass drivers (for car) that I'm trying to design a vented enclosure for and I would really appreciate any advise or help you can give.
The specs I have are;
8" driver
Fs 40
Qts .255
Qes .268
Qms 5.29
Vas 30.6 ltr
Xmax 7mm
4ohm
92db/w/m
So far the best I can come up (win isd) with is 22ltr, 42hz tuning and a port of 6x17cm
Would love to see what LEAP suggest as I believe you can add room gain or in this case Cabin gain being a small sedan.
size and power required are of no importance as I will use two in an isobarik setup with a 2x80wrms amp.
Not after Boom boom, after the best deep rumble I can get from them.
Many thanks....
Edit, found dimensions of car if it helps.
Passenger volume 2,670.3L
Boot volume 322.8L
TAAAA
-CGL-
Hi.
LEAP doesnīt suggest anything. It simulates given enclosure/driver/space. You have the standard parameter set, but LEAP works best with itīs .LTD model. To be able to help, I would need additional parameters such as Re, Sd, BL....
ocaukrell
Doh, Ok, best i can do is attach a scan of the 'owners sheet'
What are those values ? can I measure them myself ?
-CGL-
Re is the resistance of the voice coil. Sd is the effective area of the cone. BL you canīt measure easily...
ocaukrell
Ok,
sd = 40 cm Squared
Re = 4.4 ohms (thats measured resistance)
Bl = yeah right ok, have various bits if that helps (dmm, generator,cro if that helps)
-CGL-
I took the liberty to guess the rest of the parameters, like dia 180mm....
Compound box, 15l net. sealed.
Les see if I can attach the graph...
ocaukrell
Ta, 15 ltr sealed, now that s a surprise, everything i've tried it in says ported.
Freind has one in a 15 ltr ported tuned to about 47hz.
Whats the chance of bigger copy of that graph ? it's not quite readable sorry.
Yup diameter is exactly 180 (cone not surround)
Thanks for your help.
Page generated in 0.14502811431885 seconds with 16 queries,
spending 0.10766625 doing MySQL queries and 0.03736186 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
Please support our sponsor.
