diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
T-amp Diy ? - Click HERE for Original Thread
nico38
I would like to know if there is a way to build my T-amp myself.
because it's hard to find in France and seems to become harder every day and I don't want to buy the Super T-amp now.
does it exist some close projet I can build-up myself ?
tanks a lot
Nico38
theAnonymous1
AMP3 kit?
www.41hz.com
cpu8088
i thought it is easy to buy t-amp thru ebay usa
panomaniac
AMP6 kit?
www.41hz.com
Bonicon
I just bought 3 units from thinkgeek.com, they serve international customers, shipping to Japan took just a few days in my case, so if you are really after a t-amp ordering from them is an option.
pikkujöpö
I also recommend the AMP6 kit .
Altough I have not yet listened one or started building mine (it should arrive any minute:) ) the kit shouldn't be too difficult to solder even for beginners.
The kit is suplied with 11 pages of instructions with customer service and 41hz forum... can you ask for more.
theAnonymous1
quote:
Originally posted by panomaniac
AMP6 kit?
www.41hz.com
Mockery!!!!:nownow:
But yes, AMP6 is a good choice if your a beginner. I forgot it was even an option.
nico38
ok thanks a lot for all your answers
the original T-amp was out of stock at Thinkgeek yesterday but is due to come back in a few weeks so I'll wait and order there
Nico
panomaniac
quote:
Originally posted by theAnonymous1
Mockery!!!!
Not at all!! Imitation is the sincerest form of flattery, you know. I couldn't say it better, so I just said it different. :D
Yes Nico, Think Geek are good to deal with. I buy from them too.
colonelkernel8
Hey, what modifications would I have to make to twist the AMP6 or 3 into a headphone amp? I hear T-amps make amazing headphone amps.
phn
No headphone amp is possible with AMP3 and 6. It is. But you will have to rewire the headphones. That makes it a no.
audiosteve
What kind of headphone rewiring would have to be done and why??
The only issue I see with using cans and T-amps is that the amplitude response tends to be load dependent with highs rising when the amplifier is playing into higher impedances. And headphones typically have a much higher impedance than loudspeakers. So the frequency response could be pretty bright with cans. Perhaps a parallel load of 8 ohms on the output would cure this???
audiosteve
Oh!! I just had an epiphany. Is the rewiring required because of the common ground used on headphones??
Variac
Good job epiphanying ;) you got it.
Some highend 'phones- I believe the Sennheiser 600 & 650 at least , have detachable cables at the earcup. This makes the process a lot less scary, you can mod the original cabes without opening the thing up.. If you screw it up you can order replacement cables..
panomaniac
The rewire is the main thing. But there is much more to it. The amp needs a load of somewhere near 8R, plus you need to attentuate the output by about 10:1.
For starters.
I do have a project on the back burner that will allow headphones to be properly driven by a small T-Amp, and no rewiring needed. Someday I'll get to it.... :rolleyes:
Page generated in 0.044647932052612 seconds with 17 queries,
spending 0.01437879 doing MySQL queries and 0.03026915 doing PHP things.
