diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Mid Front Horn Question - Click HERE for Original Thread
audioaction
I've recently learned to work with fiberglass and would like to make a front loaded 300-500 hz mid-horn. I'd like to use the Fostex FE 127e .Given the Fs is 70.4 Hz could I do this, or is this driver really only suited for BLH configuration. Any suggestions or comments would be appreciated.
GM
Greets!
Based on the published specs it has a <300 Hz mass corner, so a waveguide (WG) is more appropriate.
GM
Page generated in 0.017750024795532 seconds with 16 queries,
spending 0.00905013 doing MySQL queries and 0.00869989 doing PHP things.
