diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
BeO - Click HERE for Original Thread
Nixie
I got some thermoconductive ceramic spacers from eBay, but I don't know the type of ceramic. How do I make sure they are not beryllium oxide, which is highly toxic and often used in such applications?
infinia
Hi
I have a very fuzzy memory about the color but they seem to look very darkish metallic or something similar to anodized aluminum. All the ceramics are white(ish). I would not worry about it unless you are going to machine them and then snort the dust. Much more things to worry about.
Nixie
The ones I have are purplish, but probably dyed.
anatech
Hi Nixie,
Look here for some hints. http://www.watlow.com/literature/pr...20insulators%22 Do not try the melting point test.
High voltage stuff again eh?
-Chris
john curl
Don't mess with them. If you are concerned, use something else, but
DON'T mess with heating, scratching, etc. White is also normal for BeO.
anatech
Yes, white or off-white.
Hi John,
I think Nixie is looking for the very high voltage breakdown rating on these. He is hoping they are BeO types.
Everyone else, get rid of them at a hazardous disposal facility. This you don't need.
-Chris
john curl
I just looked at my selection of BeO and Al TO-3 spacers. The AL spacers have AL stamped on them! BeO? No ID. IF the spacers are unknown in composition and say NOTHING on them, presume they are BeO! Go figure, you would think that they would be marked, BUT they are not.
Nixie
quote:
Well, I can reach that temperature, but the thing is I don't have a way to measure it.
There is no label on them, and I think they're Russian military old stock (I got them from kwtubes on eBay).
They seem a bit more powdery than the alumina and magnesia ceramic crucibles I have.
According to the article, only inhalation of the dust is a hazard. "Handling of solid shapes presents no dermatitis or skin absorption problem." I figure as long as I don't try to machine them without a mask, and avoid applying friction to them, it should be safe.
As for my high-temperature/high-voltage stuff, I'm not using ceramics but sapphire, which has a higher melting point and is much stronger (though machining it is difficult even with diamond bits under water).
anatech
Hi Nixie,
Not that you should do this, but you can rough guage the temperature by what colour a known substance glows at. Another thought, can you test the breakdown voltage reliably? That might be safer.
Hi John,
What where they thinking? I thought they were supposed to be marked. I had some that were. I got rid of them as I never have a need for anything over mica.
-Chris
jneutron
Marking is not required on either alumina or beryllia.
Product using BeO needs an identifier.
It's perfectly safe to have and use BeO..as stated, inhalation is the only hazard. It is not toxic orally, nor topically.
Go to the Brush Wellman site, they provide a good explanation..
BTW, roughly 4% of the human population is susceptible to berylliosis. As of ten years ago, from what I recall, there was no test capable of determining susceptibility, therefore all are considered susceptible.
If I were in your position, I'd do a thermal test. BeO has themal conductivity of aluminum, alumina is 1/5th that. Mount a device, push power, alumina should be about 3 times the thermal drop.
material thermal conductivity, W /inch C
Cu 10.2
aluminum 5.3
BeO 6.3 note: actually it is (340-T)/61.7
Alumina (99%) .94
Cheers, John
mirlo
BeO is 3.01 g/(cm)^3.
If that is sufficiently different from other materials, maybe that is the easiest test.
-- mirlo
Page generated in 0.04525089263916 seconds with 17 queries,
spending 0.01050401 doing MySQL queries and 0.03474689 doing PHP things.
Please support our sponsor.
