diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Pioneer VSA 805S Probs - Schematic wanted - Click HERE for Original Thread
Omegasteffy
Hi, im am trying to repair an older Pioneer surround amplifier (VSA-805S) and are in need of a schematic. I would be happy if anyone were able to email it or link to it.
The problem is that the Left channel does not work if it is loaded and a signal is applied. If i connect a speaker the amplifier will report "Overload" and enter standby mode, once i turn the volume knob.
I tried to measure voltage at the Collector of the NPN output transistor and the at the driver. Here the supply drop from 47 V to 44.3 V before the amplifier report overload.
The power amplifiers are mounted on a pair of prints which are sperated from the remaining amplifier (signal processing, control and PSU). There is a overload line from the power amplifier which seems to be digitally controlled. A negative pulse occur on the overload line before the amplifier goes into standby.
I think it could ease the the repair a lot if anyone had a schematic or a service manual.
PS. On the amplifier modules there are made room for an extra output transistors and i guess that the same modules might are used for larger surround amplifiers from the same year 1996. I am not aware of which models this might be.
Leolabs
Try to check for shorted semiconductors and dry sloder joints.
Omegasteffy
I will try to resolder any doubtful solderings.
Yesterday i found a bad connection on the emitter resistor of the left channels power transistor. It is a shared power resistor and i resoldered all three pins. Thereby forgot to note whether it was the positive or negative part where the connection was gone loose.
Omegasteffy
Uff! It seems i might have found the flaw. It tried testing with a variable power resistor and it did not seem like it got overloaded until i went down to approx 2 ohm. I tried swiching speakers and now it seems to output sinus tones just fine. I guees i fried the speaker before i found the bad emitter resistor connection or maybee the speaker was already fried. So i think have spent a few days wondering why the amplifier did not work with this speaker, when the problem actually was the speaker :rolleyes:.
I will bring it home from the lab and test with music and other speakers.
Page generated in 0.022984027862549 seconds with 16 queries,
spending 0.00873041 doing MySQL queries and 0.01425362 doing PHP things.
Please support our sponsor.
