diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Internal speaker wiring - Click HERE for Original Thread
type
I ussually use 12 guage speaker wire to connect speakers to my receiver. So, it would seem to make sense that I use wire at least that guage to wire the inside of a diy speaker. How important is the guage of wire used inside a speaker?
preiter
At least as important as the wire you use to connect it to the amplifier.
Doesn't make much sense to use expensive wire for the long run from the speaker to the amplifier, and then to cheap out on the short run inside the speaker.
Scottmoose
To an extent, I'd agree, aside from thinking expensive wire is the biggest rip-off known to mankind. It's important, but what you use should also depend on what you're hoping to achieve, and what the rest of your system is like. I usually use a 24AWG twisted pair for internal wiring with FR drivers, for example. Adds a touch of series resistances, boosting Qe and proportionally lowering Qm. For more regular applications, 12AWG zip cord is fine.
Page generated in 0.016663074493408 seconds with 16 queries,
spending 0.00754619 doing MySQL queries and 0.00911689 doing PHP things.
