diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
I'm a bit worried... - Click HERE for Original Thread
bulgin
Hi All
I've just replaced my 405's electrolytics with two big 'uns rated 10'000uf/100vdc in the place of the previous items which were rated @ 63vdc. A friend sent me today some further upgrade data where the notes mentioned caps rated up to 22'000uf, but always rated at 63vdc. The author also mentions that he is 'not sure if the rectifier will survive the much higher start-up current'. Does this caution only apply to the higher capacitance or to the dcv as well?
My amp is fine after the change to 10'000uf/100vdc but is it at risk of frying the rectifier due to the increase from 63 to 100vdc?
bulgin
poobah
It is only a function of the capacitance. The voltage rating will just mean that the cap is physically larger and more costly.
bulgin
Hi Poobah
Thanks so much! What a relief!!!
bulgin
Page generated in 0.09121298789978 seconds with 16 queries,
spending 0.02435112 doing MySQL queries and 0.06686187 doing PHP things.
