| Luck |
Project Tube and ic amplifier PCB or kits
I have a project using tube 6922EH(OR ECC88)as input buffer,
LM1875 as power output IC..I had finished the engineering working sample. You can get more information in AMP Chip ......
Now i am going to make a update version of the PCB, who is interesting in this project? I think the price of all the materials in the PCB will be controlled under 40$ including the tube,ic,and heating.......
Hope more froends will join in this project.... |
| Luck |
| here are some reference sch... |
| Luck |
| My engineering working sample..... |
| Luck |
Here are some pictures of the PCB with components. The PCB size is 20*15cm, 1.6mm FR4 material.
The tube we can use 6922EH or 6DJ8 or ECC88 or E88CC or 6N11...... |
| Luck |
| picture of the tube .....below the tube is LM7806 for heating the "lamp" inside the tube. |
| Luck |
| The relay part using LM7812 , when power on, the relays will be conected after around 10 seconds......during this 10 seconds, LM7806 is working and heating the "lamp" inside the tube... |
| Luck |
| using two LM1875 IC for power ouput.....20W+20W power can be output when connected with 8_ohm impendence speakers... |
| Luck |
| The rare side of the PCB after soldering all the components. |
| Luck |
About the power supply:
20V~-----0V------20V~ 3A is suggested for LM1875.....(120W)
18V~-----0V------18V~ 3A can also be used in this case.
12V~ 0.5A is for the relay part. (6W)
8V~-----9V~ 1.0A is for the "lamp" inside the tube.(8W---9W)
So, the power of the transformer shall be around 150W in this case. |
