| albertli |
I recently got a pair of Coral Flat 10. Does anyone out there have inforamtion about the speakers? I'd like to put them in a horn speakers. Is there any suggestion what to go? or any good ideas would be welcome.
Albert:smash: |
| albertli |
Offanonone,
Thanks for the info. I'll try talk to the owner of DIY Paradise.
Albert:smash: |
| lovechild |
Hi
I once collected this from the coral catalugue...
and some messured data from I don't know were.
hope it helps!
best, LC
edit: sorry, the pics are to big to attach, if you email me I can send them over |
| ingvar ahlberg |
Hi Albert
The best You can get with the flat 10", an amasing driver, is the Schmacks horn, use the plans for 8" driver and move the first wall of the "cone" one inch so You open the "throat area" about 5mm per side. I have modified the Schmacks design for Beta/flat 10"
units, a lot more complicated to build but if You want drawings let me now.
Ingvar |
| albertli |
Hi Ingvar, and lovechild
I really would love to email you guys. I've tried couple times to get your's email, but the web stop me from doing that. May be I didn't catch how it function yet. Would you please send me the drawing to my email.
Thank you to both of you
Albert |
| lovechild |
Hi Albert,
unfotunately I can't email you through the forum as that is disabled in your profile.
to email me, just click the email button below - or send mail to "flat at snafu.de"
best, LC |
| BTW |
The Flat 10 is similar in specs to the Beta 10 so you can use the Coral designed BLH for the Beta 10 or you could also put it in the Coral designed BR box for the Beta10 like what we did.
The highs were a bit weak so we added the ESS AMT tweeters on top , a very musical combination |
| 4fun |
Beautiful nice drivers, seldom seen today! (At least not by me).
Do anyone have some info to share about Coral's history, it would be interesting.... |
| BTW |
| quote: | Originally posted by 4fun
Here you go...
http://www.eastmarinedrive.com/cont...lfr-content.htm
East Marine Drive's website probably has the best Coral documentation around. Btw there's also a interesting Flat 10 cabinet design right down below. |
| 4fun |
Thanks for links!
It's pity that Coral is no longer....... :( |
| albertli |
Thanks guys. All info gave a lot of help and let me know a bit more about this driver.
Thanks again.
Albert:smash: |
| albertli |
BTW,
Can you tell me the size of the pipe?. Please.
Albert |
| BTW |
| quote: | Originally posted by albertli
BTW,
Albert |
East Marine has the plans for this 5 port BR Coral box, which you can download. The diameter of the pipe is 75mm in diameter. This BR box is simple to build and sounds very good too. |
| harryz |
Hi Albert-
I used my flat 6Bs in tall straight pipes, similar to the Cain and Cain Abby. These are modified Voigt pipes based on Martin King's and Bob Brine's design, located on the fullrange driver forum.
Harry |
| albertli |
BTW, Thanks for the reply
Harryz, Does the bass good? I love bass, a lot of bass.
Albert:smash: |
