diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
93C66B EEPROM and forgetful memory - Click HERE for Original Thread
rtarbell
Our cash boxes at work use the 93C66B serial eeprom to hold their electronic id. The problem is, when we electrically connect and disconnect the cash boxes from their computers after many times, the eeproms keep getting a few of their memory locations changed, and if even one memory location is bad, the cah box won't work. Is there a more "robust" eeprom that is compatible with the 93C66B?
prorms
i dont know for sure but i think its static electric thoes parts are very sentive
if you do change the part or find replacement those part are preprogram they software on
im just a hobbyist
more i read your question over its static electity
Page generated in 0.030965089797974 seconds with 16 queries,
spending 0.01166797 doing MySQL queries and 0.01929712 doing PHP things.
