diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Input transformer for Inverted GC - Click HERE for Original Thread
5150ed
I want more gain from my inverted GC but I do not want to add buffer or tube buffer, want to keep it as pure and simple as I can.
So is 1:4 input transformer works for my inverted GC, if yes what is the input Impedance work for the application?
analog_sa
Bad idea. The reflected input impedance is likely to overload the source. What's wrong with the chip providing gain?
As much as i like transformers they seldom provide voltage gain for free.
5150ed
Dear Analog- Sa
I am using OPA541AM ship and having problem with it gain.
Firstly, I used common inverted GC schematic which have 22X gain and I got problem with high frequency distortion.
So I reduce the gain to 12X and very satisfy with its sound but not its gain coz I use it with step as passive volume.
I want to reduce the gain to 10X and adding one input stage but still want to keep it passive.
Any suggestion?
analog_sa
The high frequency distortion is probably intermittent oscillation.
What might help:
- PS bypassing on the chip pins
- output Zobel
- small resistor in series with output
- a better grounding scheme
Peter Daniel
Or changing the speaker cables.
5150ed
Can you explain more on these term?
- output Zobel
sivan_and
Small 33pf to 100pf between +ve and -ve inputs...
Zobel:Rc network 2.2ohms/2watts and 100Kpf across the output
analog_sa
That certainly isn't PS bypassing on the chip pins...
quote:
100Kpf
You mean 100KuuF, right? :)
Page generated in 0.023339986801147 seconds with 17 queries,
spending 0.00774574 doing MySQL queries and 0.01559424 doing PHP things.
Please support our sponsor.
