diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
tda2007A internals ? - Click HERE for Original Thread
ash_dac
I opened up my pc speakers and they contained a tda2007a chipamp.
The ST internal schematic is making my head hurt !
What type of input stage is on the tda2007a ?
http://www.ortodoxism.ro/datasheets...ronics/1454.pdf
DJ Exprice
Explain what you are using as a schematic for the real amp. I might be able to tell you if you are going to need to fret the internals or not. ;) Don't worry for now.
PS: I think I might build one of these :)
ash_dac
The chip was inside my active pc speakers powered by a 12V dc supply. Looked to me like a standard datasheet implementation. The potentiometer was failing after four years putting dc onto the left speaker (which is now failing) and throwing the balance way off.
After searching the forum I think the chip has a single common-emitter input stage.
Here are the speakers. Can't do that with a flatscreen!
ozonek
The input stage is a common emitter single transistor amplifier followed by a emitter follower. The equivalent internal circuit diagram seems to have broken the rule that input to output is usually drawn from the left to the right.
Page generated in 0.0225510597229 seconds with 17 queries,
spending 0.00770807 doing MySQL queries and 0.01484299 doing PHP things.
