| 5150ed |
As OPA541AM has 10A max continous current and 5A norminal continous current, what should be the best suited tranformer for it?
I want to use only one tranformer for both chennals.
Is 16V-0-16V 10A is enough for the application? Or any other suggestion? |
| gengcard |
As I read in Ti website, they suggest this IC is not suitable for any new design. I think OPA549T is better for Gainclone.
For 16V-0-16V 10A transformer, it's enough for the application. If you need more power, 20V-0-20V may be better. |
| 5150ed |
Thank u for the answer.
But I already have a pair of OPA541AM. |
| gengcard |
| As I assembled this OPA549T, I think it is sensible with any spark that is a cause IC damaged. :bawling: Two of mine were damaged and this IC is quite expensive. |
