diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
beginner want to make device... - Click HERE for Original Thread
evo1622
* First of all , I am sorry about that my english is too bad , hope you can understand what I say >< *
Hello~ I am a student , I am on hoilday now...
I want to make a audio device during my hoilday ...
however , I don't have any PCB or instruction
Do you have any PCB which is suitable for beginner ?
DJ Exprice
You might want to try making an LM3886 Amp.
They're easy to make, and very nice sounding.
I recommend either buying a www.chipamp.com kit or, if you are an extreme DIY-er, use Russ White's PCB layout: http://www.diyaudio.com/forums/show...0642&highlight=
I still need to finnish my first one I started to build!:D
ahrsix
Hello evo1622, and welcome to the site. You need to say what sort of circuit or PCB you want, you say audio, but do you want to make a simple doorbell or a stereo amplifier? I wish you luck and I hope you find what you want. Your English is very good I have tried to learn a different language but I could not do it, well done.
ahrsix
evo1622
I am sorry about that I didn't say what kind of audio I want to make ~:(
I want to make a amplifier
:angel:
thank you for your help :D
ahrsix
Hello again, what power do you want ?
davidlzimmer
Either BrianGT
Or Peter Daneil
offer fine kits at a great price.
evo1622
I don't have any idea in power of amplifier , that amplifier is for study
this is my first time to build an amplifier
Do you have any suggestion?
Furthermore......
Is PCB possibly made by me?
I bought some PCB etchant .
Can I draw a circuit on copper borad , then use the etchant to etch it?
DoomPixie
I might aswell point out that there are chipamp circuits out there that are simple enough not to need a PCB.
One i built a while back for instance, sounds ok, enough power to drive pretty much anything, uses cheap and readily available parts, and best of all its simple! http://www.oselectronics.com/downlo...1554Q_CNV_2.pdf
I used the schematic in the datasheet for a stereo amplifier but changed the input caps for 1uF cap's anything between 1uF and 10uF works well as input caps on this amp.. there is a noticable difference useing lower values than this..
I havent tried anything above 10uF. i tried 10uF non polar electros but liked the sound these 1uF polypropelyne caps give better so i am sticking with them.. :) it is nice and simple and deffinatley dosnt need a PCB..
Runs quite happily on a little 12V SLA battery or i am useing a small 100VA toroid which is giving me about 18V after rectifier and a single 4700uF filter cap bypased with another 1uF cap and it is perfectly happy running from that aswell.. :)
Hope this is of some help,
Owen
davidlzimmer
If you are TRULY a beginner and wanting education more than a disired result try HERE
They offer all kinds of kits, many which run from a battery.
DJ Exprice
quote:
Sure, a battery could be used, but if you think you can be careful with AC primaries and secondaries, I say go ahead and try a transformer with a bridge rectifier and some smoothing capacitors.
Just wire that up like it says on www.chipamp.com 's website - the snubberized power supply.
AC to DC: AC Transformer secondaries to Bridge rectifier to Smoothing capacitors to DC
Leolabs
Hi,evo1622.You might take trip to ShengZhen.There are lots of amplifier kitset to choice from.
Mick_F
Have a look at this: it's a copy of the famous Gaincard and can be made p2p.
Mick
Page generated in 0.05441689491272 seconds with 17 queries,
spending 0.02512431 doing MySQL queries and 0.02929258 doing PHP things.
Please support our sponsor.
