diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
AlephX PSU- need help - Click HERE for Original Thread
bach2800
I'm building an alexh-x but a problem appear when at the initial testing of the PSU with no load on it. It keep blowing fuse.
I'm using a crc filter with 2 bridge, 56000uF - .25R - 56000uF. The fuse I'm using is 8A slow blow. something like this: http://s37.photobucket.com/albums/e...ent=LOIC_PS.jpg
The transfo is from ebay, initially 240V input, 4x 38V output rated at 3700VA. I'm running it at 120V and get about 19V per secondary.Let me know if you think you need some more info.
Thanks for your help
Thierry
metalman
Are you using the NTC shown in the figure you referenced? If not, the initial current draw to charge the capacitors will easily blow the fuse.
Second, have you tried starting the power supply up slowly using a variac? That will give you some clues as to where the mistake might be.
Lastly, a good high wattage power resistor doesn't cost much and will provide a decent load to the power supply for testing purposes.
A few points to try and if they don't work out, we'll try some others.
Cheers, Terry
bach2800
I'm using 2 cl-60 one on the hot and one on the neutral
Could it be possible that 8amp fuse is not enough?
I didn't try with a variac but I'll get one tomorrow.
As for the load I have a 33R around 50-100W, would it be good for that purpose? I was not using one so far because I don't want to add more inrush til it work.
Thierry
jh6you
If it is 3700VA at 120V main, the current handling is about 30A on the main side. In addition, there will be very high inrush current. Probably, there should be fuses on the secondary side too. Ayo . . . have no idea how to estimate the fuse size in this case . . . Nevertheless, the 8A slow blow is considered too small.
TS Lo
quote:
In this case - the transformer can only handle about 1800VA since the
copper wire used in the primary winding is only enough for (3700/240)
15 amp.
TS
kropf
In the absence of a variac, try a light bulb in series with the transformer primaries. This will keep the fuse from blowing and let you look around to see if everything else is working fine.
Jeremy
bach2800
Problem solve, I happen to had a short capacitor who was pulling the juice. The variac was very handy in troubleshooting it.
Thank you all for your reply
Thierry
Page generated in 0.024169921875 seconds with 17 queries,
spending 0.00668836 doing MySQL queries and 0.01748157 doing PHP things.
