| soundNERD |
I'm trying to modify the following circuit to work with a single, non bridged LM3886.
A lot of parts appear unneccesary, like the 2.2k resistors between power supplies, cap/resistor across driver, etc.
And since each side isn't identical, so I'm not exactly sure where to start removing comonents.
What can I remove from this circuit to use it with a single LM3886 with a pair of MJ15003/MJ15004 transistors. I'm looking for power over quality here, it's going to be driving a horn subwoofer so although sound quality is important, power output is even more important.
| lndm |
| The 2k2's across the supply appear to be creating a ground reference. The cap and resistor across the driver are there for stability, a speakers load typically rises beyond the spectrum. I'd leave those there. |
| soundNERD |
| But the 3886 requires split supply so a physical ground is there anyway. Or do you mean something else? |
| lndm |
| The schematic showed a non centre tapped supply. Of course you'll want to add one ;) |
