| DJ Exprice |
I have made an improved (and not had any doubts like in v1.0) GainClone Regulated Power Supply.
Have fun!:D
Click here for Hi-res image of PCB.
Note: This PCB image has been flipped vertically. If you plan on etching it, please make sure NOT to flip it again.
More Pictures:
Screenshot 1
Screenshot 2
Eagle Board File:
Eagle Board File |
| DJ Exprice |
The Eagle Board HiRes Image above and the two screenshots are no longer identical to the Eagle Board file. I had to change something so that if you wanted to get a board milled, there would be fewer trace problems. I fixed a trace around Diode 10 (D10) and around Jumper 2 (J2) so that there would be a little more space. Just to be safe, don't try to mill with the HiRes Image by tracing it. Etching with the HiRes Image should be fine. ;)
Happy milling! :D (or etching for those who have the etch OK HiRes Image.) |
| DJ Exprice |
I just updated all of the files. There was a HUGE mistake on one of the traces! :bigeyes:
All better now! :D
I've even included a PDF of the etch-able board diagram. All images and files are IDENTICAL once again :D :D :D :D :D :D :D :D
I hope you all see this post if you downloaded before so you can update the files!
Cheers! :D :drink: :D
I hope this is a final error fix!!!:rolleyes: :D ;) |
| DJ Exprice |
| Anyone interested? :( |
| DJ Exprice |
| Anyone? :bawling: |
| DJ Exprice |
| :confused: Hello?:dodgy: :cannotbe: :bawling: |
| Zen Mod |
| don't worry-just temporary traffic jam ;) |
| DJ Exprice |
| quote: | Originally posted by Zen Mod
Oh, okay :D
No problem. |
| kmj |
| Sorry, can't download the Eagle Zip-file |
| DJ Exprice |
| quote: | Originally posted by kmj
Sorry about that...
Link fixed.:D |
