diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Cyrus One - Click HERE for Original Thread
hacknet
hey guys!
i just got my hands on a spoilt cyrus one int amp. from what i've checked, the output transistors have given up. the originals are buv28, but i cant seem to get them from my local retailers. i have been considering getting the BD711 to take its place, with alittle more current and power dissipation abilities i think it would be better off.
i only face one problem, i did try swapping in a pair of 3055s and the played for about a minute before resigning to the grave. i suspect the HFE is too high thus drawing too much current. i was hoping to lower the Iq but there isnt a pot to do that.
i intend to replace the lower resistor in the vbe multiplier with a 1k pot to see how it goes.
is this sensible?
another thing, i was thinking of scrapping the original supply altogether for a psx-lookalike. from what i gather, all i need to do is remove the fuses that connect the original psu to the output devices and add another one. the question here is what voltage does the supply have to be? the markings on the PCB say +/-40v, but the buv28 would not be able to that kinda trashing especially with the increased current that can be drawn with the new supply.
there are holes in the pcb for a larger output device. can anyone help me out in locating a device that would be able to take that added power or would the bd711s do.
thanks a million!
anatech
Hi hacknet,
Don't use TIP3055's.
Your new transistors may have failed due to other faults in that channel. Check the drivers and bias transistor. Post your findings.
You always need to check your bias current and DC offset when powering up a repaired amplifier. A limited power start wouldn't hurt either. I am suggesting you use a variac or lightbuld in series with teh amp as you start it up.
Don't mess with other power supplies until you understand how these work. You can only cause reduced performance or smoke without a good understanding.
There are other things that need work before you are ready to add external power supplies. The regulated low voltage supplies for one.
-Chris
AndrewT
I think the rail voltage on zero output will be a bit lower than +-40Vdc
I would aim for about +-35Vdc and with a stiffer supply it will hold closer to that when loaded.
Does the Cyrus One have 1pair or 2pair of output devices?
It's a pity an equivalent to the 15003/4 is not available in plastic package. It would cope with almost anything.
Can you find an equivalent say 150W to 200W, 15A to 20A, 100Vce to 140Vce, Ft 4MHz, hFE 40 @ 5A and 3A at 40Vce.
Fitting a temporary pot in place of the base emitter resistor will allow you to set a sensible Iq. Replace it with a permanent resistor once you have tried it.
I don't think hFE caused you second failure. Higher output device hFE draws less current from the driver which in turn suffers less stress. 3055 may have a lower hFE than buv. Either excess Iq or some other damaged component that caused output stage overheating.
hacknet
there was no dc offset on the amp when powered up, the bias transistor is fine, drivers have all been taken out, measured and put back, they are working fine too.
i cant seem to find what the original Iq was? has anyone help me on this, please?
Geoff
quote:
The measured Iq on one of my Cyrus 1s was ~75mA.
anatech
The Cyrus 1 runs about +/- 31 VDC for rails. If you have the older type (bias transistor mounted on heatsink) adjust for a voltage from 2~6 mV across R95/96. The newer type has the bias transistor mounted to an output transistor. Adjust the bias for 10~14 mV across R95/96. Let the amp idle for 1/2 hour to settle down to these figures. R95/96 are emitter resistors, 0R22, 1W.
The PSX will increase the supply voltages to +/- 40 VDC. Readjust the bias currents to compensate. If you really want to build a new supply, then try a regulated version like the PSX-R. You may want to reduce the voltages slightly as they will not droop under a heavy load. You don't want to overheat the little amp do you?
These are the factory figures and procedure.
-Chris
AndrewT
Hi Anatech,
the bias voltages; are they across each emitter resistor or across the pair?
hacknet
oh! thanks!
i had something like 30mv across those 0.22R resistors! far too much!
i was thinking of using the naim regulators from the mcbride website.
i just ordered BD711! lets see how it goes!
anatech
Hi Andrew,
Just one I think. I'll have a read. It may be Tuesday before I can respond though.
Hi hacknet,
Get it working properly first. Replace all outputs and drivers in that channel.
-Chris
KBK
Anniken:
Yah think the Big Guy's gonna stay dead?
There's two decent tranny's in that unit. And a few upside down heatsinks. Such a shame.
hacknet
with 75ma running through the output pairs, you should drop 16mv across each emmiter resistor or 32mv across the 2.
let see what happens when the new devices go in. apparently there is going to be a delay in the delievery because of the july 4th holidays!
what wrong with useing a 3055 for the output pairs, i thought they are just a spec under what the buv28s are rated. i am waiting for the mje243/253 to come in, is there any harm in running them off bd139/140 temporarily?
sreten
hey guys!
.....another thing, i was thinking of scrapping the original supply altogether for a psx-lookalike..........
thanks a million!
As far as I understand the original supply still drives the pre-amp
and power amplifier up to the driver stage with reduced ripple.
The PSX clone then just provides the juice for the output stage.
Voltage should be similar to the driver stage supply voltage.
:)sreten.
hacknet
yuppers! thanks for the advice man!
anatech
Hi sreten.
I'll check on that as well. The factory PSX delivers 40 VDC, the unit's own power supply is listed as 31 VDC. A quick look at a series 1 amp board shows the drivers share the same supply as the outputs.
I do know the supply inside the "1" powers the low voltage regulator section with the PSX connected. I am pretty sure the entire amplifier section is powered from the PSX on the Cyrus1 and 2.
To connect the PSX, just pull the fuses on the board first. Do not fail to remove them!
-Chris
hacknet
yeah, the entire power amp section is running off the psx, or the fuses for that matter. the preamp stage and the regulators are always on with or without the fuse.
anatech
Hi hacknet,
There is no point in rushing through anything. Just wait until you have the proper devices installed. TIP3055 and 2955 are just really poor devices. I wouldn't waste my time mounting them.
-Chris
hacknet
ohhh... okay.. i just didnt want to blow the more costly 711 to smitherins' over a silly mistake.
anatech
Hi Ken,
quote:
Anniken:
Are you talking to me? :)
If so, all my feelings are strongly suggesting you not repair the Mission amp. The design was seriously flawed to begin with. However, if you really want I will attempt to repair it for you to the best of my ability. I'll do the M-05 first.
-Chris
anatech
Hi hacknet,
Do you have a variac you can use? A variable bipolar tracking supply would work. If you can get it running at + / - 20 VDC at least, you should be fine at the 31 V normal supply. Double inspect your work before you apply power, remove the flux from where you solder so you can actually see if you have a short.
-Chris
hacknet
thats the hassle, i dont have a variac nor do i have a bipolar tracking supply!
i quite worried that there is going to be a repeat of what happened to my 3055s.
anatech
Hi hacknet,
Do you plan on doing more of this work?
What equipment do you have?
I can't help avoid bad things happening if you don't have some of the basic things to service properly. So you have to ask yourself if you should get some service gear, or send the amp for service. There is a reason the better servie techs are worth their weight in gold. And some of them are pretty heavy! ;)
-Chris
hacknet
well, i can bring it down to school but that is a hassle...
i think i can get by... :)
richie00boy
As well as replacing the drivers, it would be worth checking the base and emitter resistors of the drivers and output devices. The Cyrus 2 I repaired took out one of these.
Don't mess about putting in cheap outputs then getting it working then swapping them for better ones as you will only ruin the PCB, just power it safely in the first place. Use 100 ohm resistors instead of the fuses if you can't get use of a proper bench supply.
hacknet
i have a good feeling that i have actually busted the emmiter resistors too!
i'll check and report back!
anatech
I'm impressed.
Doing a job right normally is inconvenient. ;)
-Chris
hacknet
the emmitor resistors are all fine... looks like i have to replace only the transistors...
richie00boy
Did you check all driver and predriver ones as well?
hacknet
the op devices are gone, 1 channel's drivers are dead, the predrivers are fine. the vbe multipler are alright.:)
richie00boy
I was talking about resistors...
I'd replace both channels drivers as a matter of routine as well. I've known them measure OK on diode check but go cranky not long after using again.
hacknet
the resistors are just perfect!
i got dodgy 3055s once and they gave way almost immediatly although the meter said they were perfect... after checking everything, a new pair of ST ones did the trick.
Page generated in 0.058398008346558 seconds with 17 queries,
spending 0.00845599 doing MySQL queries and 0.04994202 doing PHP things.
