diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
transformer with 43VAC secontary for an allef 2 - Click HERE for Original Thread
nikosgr
Hi to all
I am in the process of building an allef 2
I have two transformers that I want to use 1500 VA secondary 2 X 43VAC
After rectification close to 59 VDC on air and under load I assume 55 volts
In the schematics of allef 2 we have 45 volts
Is it ok if I use those transformers?
Please advice
Mark A. Gulbrandsen
That is too high of secodary voltage. This is getting into Aleph-1.2 terriitory. You need to be around 33 to 35 volts ac secondary for Aleph 2.
Mark
nikosgr
Hi to all
Thanks for the replay
Watt if I use a CRC filter bank , I assume that I will loose sum volts there depending
On the value of the resistor
Please advice
jh6you
Unless your speakers require high current, I think that you could use the 55V with a reduced bias current by adjusting R19, e.g. down to 0.4A/FET instead of the original 0.5A/FET, keeping the same power consumption of the amp. Of course, the reduced bias might affect the output power rating fairly much, though.
Mark A. Gulbrandsen
The reduced bias will also affect how the amp sounds. It won't sond like an Aleph 2.. thats for sure. Burning up 10 volts in a CRC will make alot of extra heat... but if you don't mind the heat then go for it. Keep in mind that the Aleph 2 runs very hot as it is.. also incresing the bias is generally more effective towards even better sound than decreasing it... at higher bias levels it gets way hotter! Once you decide on the heat sinks then double that amount and you might have enough!
Mark
xr000
:smash:
jh6you
Mark,
I do not deny your claim about the sound. I just thought about using the existing transformer as Nikosgr wishes. If a new investment to a new transformer has a good money value for the sound, that could be better. :)
In my opinion, the total current with the reduced bias is still more than Aleph 3 and more over the rail voltage is much higher with a positive effect. If the shared bias current 0.4A/FET is considered too low, we could increase the bias/FET by reducing number of paralleled FETs, e.g. 0.6A/FET * 4 (total 2.4A) instead of 0.5A/FET *6 (total 3A). Of course, the amount of bias is adjusted by changing size of R19.
Page generated in 0.19262790679932 seconds with 16 queries,
spending 0.17335439 doing MySQL queries and 0.01927352 doing PHP things.
