diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Help Fixing Bias - Click HERE for Original Thread
dsavitsk
I am using this circuit as the gain stage for a DAC
http://www.diyaudio.com/forums/atta...tamp=1150150590
It sounds remarkably good, but it has been suggested to me that converting it to fixed bias might be a good thing. As I understand it, this would mean removing R2, R3, and C1, jumpering over R3 and C1's spots (that is, tying the cathode to ground) and applying a negative voltage to the grid -- I guess between the grid stopper and the input cap.
So, the questions are (1) does that sound correct, and (2) what is the best way to apply this voltage? It seems that any ripple at all is just going to be quickly amplified, so perhaps a battery with the + terminal tied to ground? And, will there be any current drawn from the biasing voltage? Thoughts?
-d
Merlinb
You are correct, technically. You can do it with a battery, but place a resistor in series with it (1M or something) to prevent short circuiting whatever you plug into it. Batteries are noisy by the way.
You could probably just replace R3 and C1 with an LED instead, it'll give you the same advantages with less of the hassle and noise. Obviously, the colour of the LED will have a baring on the bias voltage it drops, so chose wisely.
lndm
Come.....join us in the red light district :bigeyes:
:D
dsavitsk
I'm not opposed to LED biasing, but I need about 6V. I suppose this requires a few in series? Any suggestions for which color?
lndm
I believe SY recommends the standard (old) red types, and I am happy with those too. Series stringing is acceptable. I have even added ordinary diodes to the string to make up parts of a volt with no regrets, but YMMV, LED's are the recommended devices.
ray_moth
Hi Indm,
What voltage would red LEDs give per diode?
arnoldc
in my experience-
red = 1.5 - 1.6
orange = 1.8 - 2.0
lndm
and I get between 1.9 and 2.05 per, depending on the current I pass through them. BTW I've had my LED's sitting around for more than 10 years.
Shoog
Old Orange and Green LED's give 2.0V drop with about 6-8mA of current.
Practically all new RED LED's drop about 2.5V these days. Other colours higher. These are not as good as the old LED's as they also have higher resistance. Salvage from 80-90's equipment might be a good source of the 1.7V Red LED's.
Watch your currents, LED's only sparkle at over 7mA of current, below that they sound flabby.
Shoog
Page generated in 0.029397010803223 seconds with 17 queries,
spending 0.01183391 doing MySQL queries and 0.01756310 doing PHP things.
Please support our sponsor.
