diyAudio.com diyAudio Forums Archive > Top > Source > Digital
DAC question from a novice - Click HERE for Original Thread
fishwinker
I'm trying to put together a system for my Dad, with the only instructions being that it has to be so small that my Mum won't even notice it's there - definitely no full-width components, and if it can be in a wooden box, so much the better...
So. I'm going for a T-Amp which I'll probably mod whilst putting it in a nice case, powering some simple full-rangers. For the CD though, I was wondering whether it might be worth using a CD walkman with a digital out, feeding into a DAC? I have absolutely no experience with DACs, or knowledge of the quality of the digital output of CD walkmen, so any thoughts would be welcome.
Many thanks, Philip
phn
I had an original Walkman, but never anything that takes CDs. So somebody else will have to fill in the details.
IF you can take a digital signal from a Discman, or whatever it's called, it will make an as good a transport as any. Everything else is just hype and marketing.
fishwinker
Thank you phn - that's what I was hoping.
Does anyone have any other suggestions though? If my father had even a single computer-friendly bone in his body, I'd probably have tried to get him to use an iPod with lossless recording, but seeing as he doesn't, I'm stuck with trying to find a way of letting him play CDs in the smallest way possible.
Does anyone know of a DIY DAC which accepts an optical digital input?
Many thanks.
leadbelly
quote:
They sort of ALL do that :)
Maybe you should be more specific, are you asking this because you want to buy a PCB or a kit, or because you don't know enough to add the optical input yourself and need it detailed in a schematic and parts list?
fishwinker
Hi Leadbelly,
Ah yes... I seem to be showing my (complete!!!) lack of experience there. A kit would definitely be my favourite route. If I got something like the Monica from DIYParadise, would it be relatively simple to make it work with an optical input? Could you recommend a well-written book or something which covers this?
I'm not overly concerned about the level of fiddlyness/difficulty - I'm patient, and pretty good with detailed manual work.
phn
This might not be exactly what you look for, but covers the actual DAC.
Doede Douma sells a DAC. Maybe there's the info you need.
Puffin
If you buy the Monica kit, you will have to provide a case for it. I bought a LiTe Dac ah TDA 1543 non o.s dac for just over £100 delivered from Hong Kong. Optical/Coaxial input and in a case as well ! Look at diyclub.biz. Most people modified these before they were even properly run-in. Why ? sounds great to me for the money. I have 3 other dac's so I should know a good one when I hear it.
Page generated in 0.072001934051514 seconds with 17 queries,
spending 0.03782940 doing MySQL queries and 0.03417253 doing PHP things.
