diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
Quick bit of info for those with Ushio UHI-S400DDs - Click HERE for Original Thread
tjh
I was just reading over the spec sheet for the bulbs (http://www.ushio.com/Files/UltraArc.pdf)and noticed something that I don't think has been posted on here before: that they should be mounted vertically for the longest life span. According to the sheet you can get 20000 hours if mounted vertically, and only 15000 if mounted horizontally.
Just thought I'd mention it for anyone who is about to mount theirs.
hailrazer
The problem is that it's VERY hard to keep the arc stable with it vertical. The arc wants to jump around and change colors.
tjh
Hmm. Didn't know that. Is there any compromise for it? Like doing it at a 45 degree angle or something?
Also do you know if it would make a difference if mounted hanging from the base (base up top) or just standing straight up (base on bottom)?
Page generated in 0.017703056335449 seconds with 17 queries,
spending 0.00828409 doing MySQL queries and 0.00941896 doing PHP things.
