diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Subwoofer Eton 12-680/62HEX your suggestion? - Click HERE for Original Thread
goodspeaker
Hi
I need to make subwoofer for Home Theater so vented box to make high SPL
On Eton 12-680/62HEX. I have this driver already.
Fs=26Hz, Vas=150l, Qts=0.34
BassBox6 gave me Vb=69l, Fb=29Hz, F3=38Hz. I guess this is OK
But your advise will be welcome.
Side firing or bottom firing to make? what is difference?
If bottom firing how high should be driver from bottom?
Stiffler
Why dont you try this one...think you got enough spl from it.
http://www.dddac.de/op04.htm
fishball79
I also have this driver but intend to use it as a sub not over 100hz.
Considering my room size (9x12ft or 3x4m) perhaps a sealed design would supply sufficient SPL
I intend to measure its T/S to get more accurate box predictions.
I've heard this driver in a 4th order bandpass design in the German Ascendo System M loudspeaker and found it extremely musical. In this alignment it rolls off after 120hz.
I'm tossing between sealed and this alignment myself.
How high do you intend to cross at?
Page generated in 0.017791032791138 seconds with 17 queries,
spending 0.00795126 doing MySQL queries and 0.00983977 doing PHP things.
Please support our sponsor.
