diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
newbie needs help with +/-15v psu - Click HERE for Original Thread
XXLPeanut
Hello.
Ive build this psu
http://www.albertkreuzer.com/psu01.htm
And now for the question. When I measure my +15v it gives +24.5v, and my -15v gives -14.5v. What could this be? Could my voltage ragulator ( instead of the 4, 1N4001 ) be fried??
Any help will be nice.. Thanks
Nikolaj
Limhes
Make sure your voltage regulator is a 7815 and no 7825, that might help :)
XXLPeanut
quote:
The writing on top is
B40
0800
3702
I cant find my receipt so im not sure what number they have
thanks for the fast reply limhes
anatech
Hi Limhes,
You meant 7824, right? ;)
Anyway, a 15 VAC source should give you around 20 VDC, maybe a touch higher. Not 24.5 VDC though!
Make sure your ground trace is okay and measure your actual input voltage to the bridge.
-Chris
XXLPeanut
I just measured again, at it gives me +26.4 and -18.6. The difference is 45V instead of 30V, which also matches what I measure between + and -.
What do you mean by the ground trace?
Nikolaj
XXLPeanut
ehm.. this is wierd... when i turn the psu upside down and measure I get a pretty +/- 15V
XXLPeanut
and now when i connect the circuit to the psu I get +15V and -3.2 V
Any ideas???????
anatech
Hi Nikolaj,
If I had it in front of me, I would be checking all solder joints and the PCB for cracked or damaged traces.
-Chris
XXLPeanut
quote:
Originally posted by anatech
Hi Nikolaj,
-Chris
I will do that to start with..
When I disconnect the pcb I get +15 and-18 Volts, but +15/-3 when connected.
Im thinking of disconnecting all potmeters, switches and so on on the pcb and measure the +/- supply each time I connect a new meter or switch.. Could it be a wrong connected meter thats giving me trouble?
dfdye
Are you measuring this with a load on the rails?
XXLPeanut
no I havnt connected any instrument to the preamp yet.. only connected the pcb to the psu
dfdye
Try dropping in a dummy resistor or an LED on each rail and see if you are getting the correct voltage then.
XXLPeanut
quote:
I think one of my friends talked about this as well.. He said I should try a restistor between the output of the 7915 and ground.. Is this what u mean?
In that case what size should I choose? Im a beginner at this so bare with me :)
Thank you all for the fast replys
dfdye
I would put a 3K resistor (or something thereabout) between + and ground and another resistor between - and ground.
BobEllis
From the link you posted:
quote:
The 7915 (at least the "made in Morocco" I used) needs a small load (some mA) to work correctly. If you get funny voltages (-18.4V or so), put a resistor from the 7915 output to ground (2k2 works good). Or it might be a good idea to put the "power on" LED with a 1k5 resistor to the negative rail (take care of polarity!).
What happens when you hook up the pre board says there is an error there - check the polarities of caps, etc.
XXLPeanut
I put in two 4.7k resistors as you said, and it made no difference. What about my idea of disconnecting all swithces and potmeters?
XXLPeanut
Do you mean putting a LED and resistor in series between +15V and ground?
I already have the two resistors in, but is it enough to put one between +15V and ground?
XXLPeanut
Ok let me just summon up.
With the pcb connected, the outputdiff on the voltage regulator is 51.9V.
The writing on top of it is
B40
0800
3702
I thought I bought the right type but i could be wrong
1. How does this fit in with the +15V and -3.2 V i measure on +/-15V?
2. And should I only have a resistor between -15V and ground? not +15v and ground or how?
3. I should be able to measure + and - 15V at all times right? No matte the load ect. Only the amperes will change?
I havn't connected anything to the pcb input yet.
Any ideas?
Thanks you
BobEllis
Dig up your order and look to see what you bought - i am not familiar enough to say whether those markings correspond to some one's version of the 7815 or 7915. Go to thte manufacturer's website and download the data sheet. If the data sheet doesn't discuss marking, do a search on teh manufacturer's website for "marking" or "marking conventions"
You should have a load resistor to ground from both positive and negative regulators. You mentioned early on that you got -18 some volts on the negative side - exactly the strange behavior that the source website described as being related to not having a load. These chip regulators may need a bit of a load to make them work, then the voltage should be stable. Anything on the order of 1-3K or so ought to work fine. You can put an LED in series with each of the resistors to
Turning the board over making everything work great says that you have a bad solder joint somewhere or broken trace. Double check your joints. Reheat so that they all come up shiny.
When you hook up your preamp, the negative rail drops to 3V - this says that you have a near short from the preamp's negative rail to ground. Did you build this on a board or point to point? Check for solder bridges and components (especially transistors and electrolytic capacitors) in backwards.
anatech
Hi Nikolaj,
I still think something odd is happening with your ground (common).
What are your AC voltages going into the PCB?
What rectified DC voltages do you get from your ground (common) on the PCB, before the regulators?
These will help come to a solution.
-Chris
XXLPeanut
I've got 2x 4.7k but that should work as well right?
Ive gotten the board to show the same no matter how it turns now.. a good start i suppose. I get +15V and - 4,6V no matter if the pcb is connected or not.
Will it be safe to stick in my bass and see if a load will do the trick or could I damage it if somethings wrong?
XXLPeanut
Hi Nikolaj,
-Chris
Ehm forgive my ignorance but by ac voltage going into the pcb do you mean before or after the transformer? on the entrance to the regulator?
and im not sure I understand what u mean by rectified dc voltages before the regulator?
Man this is hard though its simple.. damn :)
edit:
the ground(common) on the transformer output is the same ground throughout the whole amp.. thats ok right?
BobEllis
Do not connect your preamp board to the supply until you have it ironed out.
You either have a short or a bad solder joint/broken trace on your PCB. Have you built this on a PCB? Where did you get it?
Anatech is asking about the voltage after the transformer. The DC voltage is the voltage after the rectifiers, but before the regulators.
XXLPeanut
Yes I build my pcb myself... its long cobberlines throughout the "pcb" so its not point to point. Im not sure what the type is called.
I think im having trouble getting whats a rectifier and whats a regulator.. I have 1 round chip, with the numbers on top i mentioned before, that gets AC from the transformer and gives, hopefully, +/- 15V.. I put it in instead of the 4 diodes here
http://www.albertkreuzer.com/pics/e...m/psu01_sch.gif
The ground is the same as on the transformer in my circuit.
I dont think I have both a regulator and a rectifier... Or am I just getting tired?
Think Ill take a fresh look at things tomorrow. Thanks for the help anyway everybody..
BobEllis
That's called a strip board - a time tested way of making a prototype. Be sure that you cut the strips where you needed to so that you don't get connections you don't want.
The round thing is a bridge rectifier. With a 15VAC transformer and some capacitance after that you should see +/- 20V or so. You can measure this across C1 and C2 - if C2 is low, check that it is oriented correctly.
The regulators (7815 and 7915) after that drop this to the 15V that you need for your preamp.
XXLPeanut
Ok thank you Bobellis.. Ill take a look tomorrow.. It 4am now so better get to bed. Thanks
es44
B40
0800
3702 :confused:
This sounds to me like it's a bridge rectifier, 40volts, 800mA, manufactured week37 year 2002.
Nicolaj, if you were close to Fredericia, i'm sure we could make it work :)
XXLPeanut
Ok i figured it out.. thanks a lot for thge help everyone .. I had a broken trace on my strip board... + my 79L15 is fried.. Guess that will explain why I got +15V but not -15.
Nikolaj
Page generated in 0.063297033309937 seconds with 17 queries,
spending 0.00894904 doing MySQL queries and 0.05434799 doing PHP things.
Please support our sponsor.
