diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Soft starter for an Aleph 1.2 clone - Click HERE for Original Thread
folkeb
I am currently building my clone version of the Aleph 1.2 monoblocks. The power supply will consist of 1250 VA and 528000uF for each block. This PS will require a soft starter of some sort. I have the thermistor CL-10, but I am, after reading threads on this and other forums, having second thoughts.
Can anyone recommend a soft starter that will work with my rather large power supply?
Thanks for any answers!
Mad_K
All you need is the thermistor... What value is CL-10? I believe Nelson uses CL-60. 10R/5A. Elfa equvivalent is called SG-42. Use one on AC-HOT and another on AC-Neutral ;)
zlast
http://sound.westhost.com/project39.htm
Phill
http://members.lycos.nl/anthonyvh/index.php?page=soft
http://www.homecinema-fr.com/forum/...2Bstart&start=0
http://domainedupossible.free.fr/pa...PH5/aleph53.htm
Phill
amichalik
Does anyone have any experience or thoughts on this device?
http://www.ametherm.com/download/Me...20DS%202003.pdf
Netlist
No experience but it's a thermistor designed for the job and I believe it will do just fine.
/Hugo
Page generated in 0.022032976150513 seconds with 17 queries,
spending 0.00705242 doing MySQL queries and 0.01498055 doing PHP things.
