diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Philips HF10 amp not working - Click HERE for Original Thread
Hanzwillem
Hello,
I got my hands on a tube amplifier mabe by Philips, the HF10, i thought it also goes under the name of mozart (?). It is a mono 10W amp.
The problem is that there are some components wandering around the case and I dont know where which one must be connected so I am searching for a schematic.
If someone knows where to get it I'll be pleased to hear it.
greetings, Hans-Willem
fdegrove
Here is a link to a site where you can buy a circuit diagram:
http://www.oldradioworld.de/advertis.htm
There are several sources on the web available offering this kind of service for restoring vintage radio and such.
Cheers,;)
ShiFtY
If you know the tube lineup, you might be able to reconstruct it with a better circuit...
Got a pic? :)
Hanzwillem
quote:
Got a pic? :)
well, I found a link to almost the same amp.
http://home.planet.nl/~mhamm/Radio/apparatuur/hf10.htm
it's the same as this one (approximately), mine houses 2 ECC83 tubes.
I have it for some time now, never looked at it because its only one channel :/
Page generated in 0.020433902740479 seconds with 17 queries,
spending 0.00782299 doing MySQL queries and 0.01261091 doing PHP things.
