diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
Light alternative - Click HERE for Original Thread
fillajarapoo
Im interested in starting a DIY projector, during my research the cost od MH bulbs and set ups are too expensive. I was wondering if any one knew a different light alternative, i have access to tons of led bulbs, reading in the forums that concept would be quite complicated. Im trying to find a light source that will do the job, and work well.
v1d9uy
cheap easy and decent = overhead projector works fine.....
Just In KY 2002
quote:
What type/brightness/voltage LEDs do you have access too? A PJ can be done with LEDs, you just need the right ones and many of them.
Page generated in 0.020569086074829 seconds with 17 queries,
spending 0.00857949 doing MySQL queries and 0.01198959 doing PHP things.
