diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
My Integrated X-Bosoz and A30 - Click HERE for Original Thread
BrianDonegan
So, I have been building an A30 for about a year. A little bit here, and a little bit there. I also have an X-Bosoz built, but not in a case. I decided a few weeks ago to get these things going to power my Klipsche's. About time I think.
So, I made up a frame out of some 3/8" aluminum bar stock (two 12x12.75 rectangles) and will bolt the heatsinks to it. Front and rear panels will be .090 aluminum, but the front piece will sit inside a 1.25" think piece of walnut. Top will be again, aluminum sheet with walnut on top of it. Large rectangular vent holes will be covered inside with heavy brass screen. Bottom will be brass screen. The circuit boards will ride on cross members running across the frame, and the various trafos (2 - 400VA 16Vx2 for A30) will ride on vertical members behind the front panel.
Anyway, I was test fitting the A30 bits, looked over at the x-bosoz, and bing. No seperate case for the x-bosoz. Also included will be a balanced darwin source selector and a joshua tree balanced attenuator.
I won't need the dual outs of the darwin, so just two knobs on the walnut front, volume and source. Will have 6 sets of XLR inputs. Will also use MaxHawk's soft power switch (red led).
Should be done in a few weeks!! Finally ;)
some pics....
dw8083
Hi Brian,
Very cool indeed! I'm surprised tha more DIYer's have not build an integrated unit.
Besure to post the final assembly pictures.
I like the big copper spreaders. I imagine it took a lot of heatsink compound to cover that surface area.
-David
maxw
I love solid metal cases! keep the pics coming ;)
BrianDonegan
I shoudl point out that the only non-wood working tool I have used so far is a hacksaw to rough cut the copper, as it doesn;t play too well with the tablesaw.
The aluminum frame was cut on a chopsaw and the panels will be cut on my tablesaw. I think if people knew how easy it was, more would be making metal cases.
EDIT: well, i did use a milling machine to face mill the copper, but didn;t really have to ;)
BrianDonegan
...also, forgot to mention (beer) that I am using Peter Daniel's A30 boards and BrianGT's PowerSupply board. Might add a second PS, even though the one I have uses 6 - 22,000uF caps ;)
choky
ugly!
:clown:
steenoe
Looks good Brian, keep it going while the spirit is there;)
Great idea going integrated, never crossed my mind. Always had my hands full keeping the poweramp cool enough;)
Steen:)
BrianDonegan
quote:
ugly!
Thanks! :)
choky
quote:
Originally posted by BrianDonegan
Thanks! :)
you are more than welcome!
angchuck
Ahhhh...... reminds me of a dream i had last night of a X-bosoz and Sussy!
BrianDonegan
Yes, yes. I know that dream... and I get the point;) working on it...
Page generated in 0.032344102859497 seconds with 17 queries,
spending 0.00972891 doing MySQL queries and 0.02261519 doing PHP things.
