diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
PR Calcs - Click HERE for Original Thread
jwatts
Am I doing this correctly? Could somebody please check my calcs. I have calculated a conventional SBB4 alignment to produce a Vb of .7ft^3, Fb=33Hz, and F-3=32Hz. My driver has such a large Vd ports are impractical for this alignment. I have assumed two 10 inch passive radiators are adequate each with an effective diameter of 8.125 inches. I have determined each radiator must weigh 292 grams. Is this correct? Does this make sense in an applied perspective?
Page generated in 0.014971017837524 seconds with 16 queries,
spending 0.00748086 doing MySQL queries and 0.00749016 doing PHP things.
