diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
Linear halogen bulbs?? Look VERY VERY bright - Click HERE for Original Thread
NeMeSiS_singh
hi,
i came across these cheap linear halogen bulbs on ebay that go into a r7 base.
They're used in work lamps and outdoor spotlights etc. They range from 150w versions to 1000w. The best part is that they're less than 1gbp for a twin pack on ebay.
check them out, this is the 500w i want to get:
auction 1
this auction has more detail:
auction 2
if anyoneknow if they would be good in a diy projector, let me know. also if anyone know the colour temp or lumens, that would be great.
cheers
mkl2
Not good, huge amount of heat and not a point light source by a long shot.
How much heat? Well, I can light up a cigarette in seconds, half an inch away from a 350W bulb.
NeMeSiS_singh
i cant really afford a metal halide lamp, only a halogen.
But i am going to be putting a 120mm fan blowing at the bulb and another 120mm exhaust.
also will i need to put a uv filter infront of it??? and will i need a cold glass on the lcd?
cheers
Page generated in 0.019036054611206 seconds with 17 queries,
spending 0.00740600 doing MySQL queries and 0.01163006 doing PHP things.
