diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Aleph x resistors values - Click HERE for Original Thread
elviukai
hello, I tried to search in forum but didnt find- why on all versions few resitors values are always diferent. I will be using 16 irf 244 Fets per channle with 22V rails and 11A bias. what value I should use?
thanks in advance..
Luke
Hi elviukai,
this spreadsheet will help you I think from memory Version 3b calculates power incorrect, use Version 3A.
You really need to use duncans psu simulator to get some idea what your final rails will be under load, especially with 11 amps bias.
http://www.diyaudio.com/forums/show...5481#post275481
elviukai
Hi Luke thanks for excel calculations. I already have 2 versions of them. unfortunately they do not tell whay they using one or other value of resistors wihich I marketed :( I am not electronic engineer and woul be nice getting nice start point. I noticed that in higher power versions it lowers from 4.7kohm to 3.3kohm. what theese resistors doing? :confused:
wuffwaff
these 10k resistors set the gain of the amp. You can leave them as they are (togheter with the 100k resistors).
Some people changed the gain by changing the 100k to 150k (x15=23.5dB instead of x10=20dB)
William
elviukai
hi wufwaf. once somebody told me to rise input sensitivity to drive via passive praemp.( I using passive preamp and wanted better input sensitivity but not lowering input impedanse) increase 100kohm value. I increased to 130kohm. get arround 15V output at speakers and quickly changed my mind :rolleyes:
ant theese 4.7-3.3ohm near input 9610 mosfets? why thery are varying. its pain when I do not know electronic basic knowlwdges :bawling: :bawling:
wuffwaff
just keep the 4k7 if possible. Lowering them betters the absolute-dc-offset behaviour but also the sound.
william
elviukai
thanks wuffwaff, and regarding theese 100 -33kohm resistors? thay also varying. and output resitors 4x 0.47ohm ,sometimes I noticed that in higher power verion people ad some pair = 6x 0.47ohm what does it means and decreasing output resitors do I need change output to ground resistors(33ohm) ?
Luke
Sorry elviukai,
I misunderstood your post.
regards Arthur
wuffwaff
Elviukai,
itīs the same story for the the output to ground resistors. Start with 100 Ohms and lower if absolute dc offset behaviour is not ok.
The source resistor value depends on the bias per fet you are using. Aim for 0,5-0,6V at the chosen bias.
The output resistors can vary too, lower values give less power dissipation and less voltage to steer the active current source. Tollerances will be bigger if the value getīs lower but normally you will set your ac-current gain with a pot first so thatīs not such a problem.
William
elviukai
start with 100ohm? all design I have ever seen use 33-22ohm(pfor example 3x100ohm)output to ground
tomorow is the big day -I will try to start up my aleph x monoblocks. 22v rails, 12.5A per channel, 16x irfp244, 1x 2Kw toroid per channel. I hope I will not blown anything as usualy :)
wuffwaff
all of these resistors (output to ground, McMillan) are neccessary evils. Keep them as high as possible. I thgink 100Ohms was the standard AX-200 value. In my Aleph-X (22V, 7A) Iīve used 80 Ohms and 10k.
William
elviukai
evil :devilr: I quess nelson do not think this way because he would remove them somehow :) if you are telling that theese resistors must be qualitty ones? or no mater metal wirewound and caddock is the same evil? I looked carefully to aleph original comercial xa100 schematic and I think I see 6-8 resitors 0.47 or 1 ohm in paralel to ground.(total about 26 resitors- 10 source resitors for each fet and left is output and output to ground)
I think my babies will be more evil at low impedances than xa200
:devilr:
wuffwaff
the evil ones are the output to ground and the McMillan resistors. Make them as big as possible. I donīt think that more than standard qualit is neccessary.
William
elviukai
where is Mc milan resistors? I have a bunch 400pieces vishay dale precision RS and CW resitors 10W 1% tolerance 1 and 2 ohms. I can paralel them as much as I need. 20x 10W woul be enought from output to ground. and also 20x 10w to output?
by the way nice to have some expalanations what pats what does in aleph x :angel: I found 4 excel files which calculates bias, heatsinks and output at selected impedance and ITS REALY helps a lot. I remeber my first alpeh 5 , I put black gate capacitor to feed LED diode :) now things are better but I still do not know basic theory. and I think most amateurs builders are feeling the same.
wuffwaff
McMillan resistors are between output and diff pair sources (4k7).
If you lower the resistance from output to ground that much you wonīt have any output:eek:
William
elviukai
no I will conect them in paalel and in series to get desired resistance :) , but I can make 200W power total is 20x 10w
Page generated in 0.038580894470215 seconds with 17 queries,
spending 0.01030445 doing MySQL queries and 0.02827644 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
