diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
subw amp install ? - Click HERE for Original Thread
dbaudio
I am going to connect my subw amp input ( hi level ) to the disconnected rear speaker wires. This way I can adjust my subw amp volume with my radio fader control. Is this the correct way to connect or should I parallel connect to the rear speakers ?
xplod1236
That would be the correct way. Do not parallel the rear outputs, because you will blow up the headunit. The 2 channels would be shorted to each other, and whatever signal difference there would be between them would result in a big current, which would fry the head unit outputs.
Page generated in 0.015374898910522 seconds with 16 queries,
spending 0.00686979 doing MySQL queries and 0.00850511 doing PHP things.
