diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
DC on second DVC VC - Click HERE for Original Thread
mashaffer
I have been doing a lot of searching for info on parameter changes for different DVC setups and if I have read it all correctly parallel or series changes only impedence and I presume driving each coild from a seperate amp channel would also have no effect.
However it appears that one can vary the Qes between the dual coil value and 2 times the dual coil value by puting a resistor across one coil and driving the other. This got me to thinking that one should be able to push Qes farther in either direction by biasing the unused coil with a DC current. If the current were oriented in a way to increase the effective power of the magnet then the Qes should be driven even lower than when both VCs are driven with the audio signal. Is this correct? Would we not then have some of the advantages of a field coil design?
If I have it right then what is the down side (no free lunch)? Just power handling and efficiency?
mike
pinkmouse
Surely putting DC on one coil would just act to move the coil in or out of the gap? I can't see it affecting any other parameters to an extent that would justify the loss in Xmax.
mashaffer
Of course... brain fog is high today. :xeye:
mike
Page generated in 0.07740306854248 seconds with 16 queries,
spending 0.04317117 doing MySQL queries and 0.03423190 doing PHP things.
