diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
how coral flat & beta driver sound? - Click HERE for Original Thread
ycliew
Hi, i looking for coral driver and would like to know how they sound? the different between flat and beta series?Thank.
BTW
The Flat series are warmer sounding, more rolled off... more musical as some woud say. The Beta because of it more powerful magnets are faster more detailed, better highs, more transparent but can be very analytical if paired with the wrong equipment. Both series are excellent drivers , synergy with rest of equipment and listening taste is very important.
ycliew
Thank for your sharing. I will go and grab the coral 6B flat driver for my first diy project.
BTW
quote:
No problem, the Flat 6 is a good driver and Yeo's price is good as well... Happy DIYing.. :)
ycliew
Hi, anyone have the idea of connected the binding post to the driver? Caused as fullrange driver don't need to have a crossover , how can it be connected.Can I have some pic or diagram of it.
Also any dumping material needed in the enclosure? Have any one try the so call 3d spiral horn enclosure on the coral driver and does it perfom?.
BTW
As there's no crossover, it's just a spk wire from fullranger to spk binding post... I've friends who want to eliminate another lump of metal(spk binding post) in th signal path, so it just spk wire connecting the fullranger out through the spk ports then all the way to amplifer. I've used thin cotton blankets to pad all internal surfaces , seems to work well enough.
Page generated in 0.37128591537476 seconds with 17 queries,
spending 0.35752392 doing MySQL queries and 0.01376200 doing PHP things.
