| farl |
Is there a benefit if i well upgrade the clock for this CDP? Cause it is connected to the PPL & VCO before it is distributed to the digital cicuit.
Or is it possible to connect the clock directly to the CD decoder and terminate the PPL & VCO.
PPL & VCO is controlling the pitch of the CDP.
Help please..........
Thanks,
Farl |
| farl |
| here is the block diagram: |
| 6h5c |
Hi Farl,
The clock distribution in the CD7300 is quite complex. Just changing the clock will not bring you much benefit, it has been discussed elsewhere. If you do a search on this (and other) forum, you will find some more info.
Ray. |
| farl |
Thanks Rey.
What about if I will cancell the clock input of the DAC and change it to a low jitter clock with the same freq. Is it possible?
Farl |
| 6h5c |
| quote: | Originally posted by farl
Thanks Rey.
Farl |
Hi Farl,
No, that won't work. The decoder and DAC need the same clock, it needs to be synchronious. Same goes for the MP3 and CD-text decoder chips that are aso attached to the clock signal. The thing that might have a positive effect is to get rid of the VCO and PLL and insert a stable clock there, with a separate PSU. You will lose the pitch control feature though.
Ray. |
| farl |
Hi Ray,
Actually this is my first option, to bypass the PPL & VCO and connect a kwack clock after this.
Thank you so much for your great help. I really appreciate it.
Cheers......
Farley |
| 6h5c |
You're welcome, Farl.
I hope it will give an audible result. Positive result that is :D
Ray. |
| Ruach |
| I had this player sometime back. The CD7300 does need a lot of work to make it sound really good and the clock part is quite tricky. Good luck :) |
| farl |
Hi Ruach,
Can you please give us some idea of what you did with this player, so that I can follow that also?
Thanks,
Farley |
