diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Just installed VAM1202..... - Click HERE for Original Thread
martipie
...on my Philips CD753, but the player is dead !
The tray opens but after closure the CD motor doesn't spin and the laser stands still in its position; the display says "READING" but after few minutes the tray opens itself.
I changed the older VAM1201 with replacement VAM1202 because I was receiving focus errors but now I'm stuck !
Where did I go wrong ?
Can you help me please ?
Pierluigi
choky
Pierluigi
on some Vams there is on bottom pcb beneath the laser, one soldered bridge (one circular dot cut in two halves)...look it is soldered or not; if yes,then desolder it
martipie
quote:
THANK YOU Choky,
I read some post about the soldered bridge but couldn't find any....but after you advice I saw better and noticed 3 pins soldered togheter in the back of the laser.
Now all it works and the player is back to life.
Live long and prosper :-)
Pierluigi
Page generated in 0.01994800567627 seconds with 17 queries,
spending 0.00780749 doing MySQL queries and 0.01214051 doing PHP things.
