diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Sub burnt bad. Garbage? - Click HERE for Original Thread
Miedosoracing
Hey guys, I hang out at the projection area, but here is my deal. I had a fusion 1404 amp sitting around, so i hooked it up. Then I had a pyle 300w sub that I had in the house for a while. Decided to play around, even knowing I would be overdriving it. Well, long story short, it lasted about 10 minutes. So, I replace the sub now with a good one. But question I have. Do I throw away the old burnt sub, or should I do something with it, like rebuild it? I don't know much about them, so if I can rebuild it, that would be ok. Thanks Chad
tade
I would say keep the magnet assembly for later experimenting and ditch the rest. I am a fatalist though.
rabbitz
Keep the old driver as it might be OK for a passive radiator.
tade
oh, great idea. If you can cut off the magnet or at least get to the voice coil to cut it off or unstick it.
Miedosoracing
Thanks everyone. I think using it as a passive is a great idea. Thanks.
Page generated in 0.020970106124878 seconds with 16 queries,
spending 0.00814080 doing MySQL queries and 0.01282930 doing PHP things.
