diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
hi-power amp schematic - Click HERE for Original Thread
ihodiputah_510
need 1000watts mono power amp schem.
please send and it wil be greatly appreciated.
thank you.
myhrrhleine
quote:
need 1000watts
New PA for the Indy 500 races?
edl
if 1000W-PMPO is enough, then let's build a TDA2003 chipamp :devilr:
Greg Erskine
This comes to mind. :D
http://sound.westhost.com/project117.htm
Eva
Rod has became crazy :D:D:D
redunzelizer
quote:
Will (hopefully) be enough to drive these:
http://www.dscnet.de/catalog/produc...roducts_id=3910 :devilr:
lumanauw
Hi, EVA,
When are you going to make full range classD? Looking forward to it :D
Eva
That's very tricky, I have a lot to experiment in that field.
AndrewT
it appears that 1000W is another man's 28W.
Makes a nonsense of test results and specifications.
I notice that our thread starter is away to check which kind of spec he intended. 1000W of what , rubbish or sore ears?
Page generated in 0.033477067947388 seconds with 17 queries,
spending 0.00943732 doing MySQL queries and 0.02403975 doing PHP things.
