diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
complementary small-signal mosfets? - Click HERE for Original Thread
bogdan_borko
Anyone knows any complementary small-signal mosfets?
Is there 2N7000/7001 or BS170 complemetary?
jcx
no mosfets are truely complementary, differing conductivity of N vs P doped Si gives different area (= parasitic C) for similar conductivity or different gm, Ron for same geometry
bjts differ too but Vbe, gm are more alike between pnp/npn
in mosfets threshold V variations and the larger Cgs,gd effects make "complementary" designs less useful in distortion cancellation compared to the fairly useful complementary bjt Vbe even order cancellation
Zetex has a few small signal mosfets - some are Supertex second sources
consider using the sot-223 package for a little more power - still big enough to hand prototype with and soldering a Cu flag on the tab can get you up 2 W
ilimzn
IRFD9110 and IRFD120 come close if I remember right...
2N7000/7001 and BS107/170 have no direct complements.
Zetex makes a few 'complements' ZVN/ZVPxxxx.
Page generated in 0.024784088134766 seconds with 16 queries,
spending 0.00745893 doing MySQL queries and 0.01732516 doing PHP things.
Please support our sponsor.
