diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Dayton DA135-8 5.25" - Click HERE for Original Thread
type
I was just checking out the drivers at parts-express and noticed that the Dayton DA135-8 5.25 inch woofer (part # 295-330) has a frequency response of, 50-15,000 Hz. Could this driver actually be used in a full range application?
Here's a link to the driver:
http://www.partsexpress.com/pe/show...tnumber=295-330
These are the links to the specs at PE's website:
http://www.partsexpress.com/pdf/295-330.pdf
http://www.partsexpress.com/pdf/295-330g.pdf
madscience
Hmm...I've never thought about using the Daytons as fullrangers. The main problem why aluminum cone speakers usually cannot be used for higher frequency lies in their break-up nodes. However, looking at the cumulative spectrum decay graph of the DA175 at Zaph's site (www.zaphauiod.com), it looks like the resonances aren't too bad. The distortion figures are also within acceptable limits. I suppose the DA135 isn't substantially different from the DA175. The DA135 has a resonance peak at 9 KHz so my suggestion is to use a notch filter and listen to the result! If you try it out, please let me know! By the way: Keep in mind that these speakers have a bad dispersion characteristic, so listen to them on axis!
Page generated in 0.019212961196899 seconds with 17 queries,
spending 0.00795722 doing MySQL queries and 0.01125574 doing PHP things.
