diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Regulated PSU from Pedja - Click HERE for Original Thread
mlampret
I just need some help about capacitor polarity on Pedja's circuit. Since the lower rail is -24V I'm a little bit confused about placing the capacitors correctly. I wonder if it's ok on the picture I attached.
The picture was taken from Pedja's page and I added some + signs where they (hopefully) should go.
-Marko
Igla
Hi Marko !
You forgot to attach the picture.If you are talking about LM338 circuit;
the positive side of the circuit: capacitor + side should be on +24V and cpacitor - side on ground;
the negative side of the circuit : capacitors + should go to ground and capacitor - side to -24V.
Regards;
Matjaž
mlampret
Obviously the picture wasn't attached.
I've placed the caps in the same way as you said. I was a bit confused because a friend suggested it was opposite.
Hvala :)
-Marko
Nordic
if you are still confused, the ones on the negative regulator is the wrong way around...
also unless I'm way stoned, you are connecting the -24 to the +24V's ground rail...
Greg Erskine
hi mlampret,
The schematic in the first post looks fine to me. Have a look here for a comparison.
http://www.tcaas.btinternet.co.uk/jlhnewps.htm
regards
Andypairo
The only way to use positive regulators for both rails is to make 2 +24V regulators and to connect them in series, as it is done in the schematic.
You have 0, +24 and +48V.
Now call the +24 your GND and you have a split power supply :D
Don't try this unless you have 2 separate secondaries and bridges.:hot:
Nordic please smoke less:D :clown:
Cheers
Andrea
mlampret
I'm glad that I still know how to connect the caps correctly :cool:
Thanks for your help, guys.
Nordic
looked totaly weird there for a second.....
but it makes sense now...
Igla
And you should put C3 and C4 directly to IC pins.
mlampret
Igla: you mean I should put C3 and C4 directly onto LM3886T pins?
I made the connections so that 2x4700uF caps, LM338, C3 and C4 and LM3886T are as close together as possible, while keeping the transformer away from the chips. And I'm planning to put the heatsinks between the transformer and the chips.
Igla
Yes; thats right.C3 and C4 should be as close as it can get to the IC.It seems to be the common practice arround here but I never really listened the difference, if the caps are in the separate box.
The same goes for the LM338 regulators.
Pedja wrote:
''C3 and C4 should be, of course, mounted at the chip’s pins and, following the same principles, regulators should be physically as close as possible to the chips.''
Don't ask me why.
Regards;
Igla
Page generated in 0.032710075378418 seconds with 17 queries,
spending 0.01038575 doing MySQL queries and 0.02232432 doing PHP things.
