diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Tannoy TS8 and two drivers - Click HERE for Original Thread
inrank
hi,
i currently have a pair of 10.5L FR125s's and a Tannoy TS8 sub.
can i run two of the TS8 8" drivers in seperate cabinets from the 1 200w amp in a seperate box?
the aim is to mount them in a same sized 12L enclosure that is the same width and depth of my FR125's so to effectivley make a floorstander.
the reason i want two seperate enclosures is because i go between home and uni a lot so two smaller boxes would be more convinient than one big one.
i wish to use the high pass filter for the FR125's at 80Hz.
and i can pick up a spare TS8 driver for around £40.
simon5
If TS8 drivers are 8 ohms each, then running two in parallel would be a 4 ohms load so if your 200W amplifier is 4 ohms stable there's no problems with it.
More information on TS8 drivers and your amplifier is needed.
inrank
hi thanks,
as i do not have the sub yet i can not tell you about it, and i can not find anything on the internet about it.
Page generated in 0.024163007736206 seconds with 17 queries,
spending 0.01092362 doing MySQL queries and 0.01323938 doing PHP things.
