diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
op-amp based preamp advice needed - Click HERE for Original Thread
Adam
Hello everybody!
I need a good preamp, line and RIAA stage.
As for the line stage, I need approximetely 6 dB of amplification.
I just browsed the solid state forum looking for a simple answer
but, unfortunately I got more and more perplexed
:bawling:
So there are few questions:
- what op-amp for RIAA stage (I thought about AD 797, would
this one be a good idea?), anyone got good shematics for this?
- what op-amp for line level, after reading, reading and reading
the forum I have three favourites: OPA627, AD825 and AD6810.
Simple question, considering the ideal aplication for each three,
which one would be the 'ultimate'???
- I guess I need buffer. BUF634 or antyhing else? Or maybe a discrete buffer? Any schematics welcome.
- Power supply. I guess it's very important. Would battery PS
be a good idea? Where can I get schem. for circuit that would
load batteries when empty?
- Volume control. Actually I want it to be IC-based, but how
about the sund of such ic-based volume regulators?
Sorry for such a lame questions, but finally I have some time
and just want start some soldering ;)
Thanks,
Adam
peranders
If you are looking for a work horse, check out OPA134/2134/4134 from Texas. This opamp can deliver rather much current also. The noise level is sufficient for MM RIAA amps but for a little bit lower noise, check for a opamps with 2-6 nV/SRQHz. Less than 1 nV is needed only for MC pickups.
OP37
LT1028
LT1128
LT1115
AD797
NE5534 (not so bad!)
plus many more....
Adam
Thanks Peranders,
but I am looking more for a specialized audio op-amps,
dfferent for RIAA and different fo Line levels. I assume that
because the difference in signal level between phono and
line I will need different op-amps to meke the most of the signal
am I right (I mean that the different op-amp will sound the best
in RIAA and different in 'live-level' application)?
Adam
peranders
OPA134 and others are very suitable for audio, read the datasheets to be convinced. Almost any opamp with slew rate >5v/µs will work but some works better. Some opamps are more suitable for "gain" than others. These are often not stable at gain lower than 3-10. Check for instance LT1028.
OPA134 will work for everything except for extremely low noise applications. I have put in OPA134 in my headphone amp (QRV-02) and I am impressed by it's technical clean performace. The step response is perfect down to gains at 1.
Adam
Peranders,
What do you think about AD6810 and AD797?
Greetz,
Adam
peranders
quote:
AD8610 looks quite impressive, the price? Notice that this chip is SMD only.
AD797 is a typical opamp for phono/mic stage
Adam
Peranders,
I would have to pay about 8 $ for AD8610. I think
I'll go for this one certain op-amp ;)
As for AD797 - i though about using it in an RIAA
circuit, would this be a good bet?
Greetz,
Adam
peranders
If you don't plan to connect MC pickups AD8610 is quite sufficient, if we talk noise.
G
Hi Adam,
I have a PCB layout that would let you use either an OPA627 or AD825 with a BUF634(TO 220 package) on the output. Below is the schematic:
G
G
Here is an image of the PCB:
G
Adam
Thanks Gavin :)
Did you use this configuraition with BUF634?
How does it sound?
Adam
G
Never built it Adam. Not yet anyway. This is what is referred to as a Jung multiloop configuration. I just decided to lay out the board one day. It keeps me sane.:rolleyes: If you would like I can send you the schematic and the board file(ExpressPCB) and you can look it over. I think that the layout is sound. I have one with two channels on one "miniboard" that is layed out to use Caddock MK132 resistors. Bu t think you could get away with others. Let me know and I'll send the stuff.
G
Page generated in 0.031178951263428 seconds with 17 queries,
spending 0.00796771 doing MySQL queries and 0.02321124 doing PHP things.
