| 82spider |
Can someone give me a quick confirmation on something. If I'm looking through the LCD from the light bulb side, I shoudl expect the image on the wall to be flipped top to bottom and side to side correct?
Want to confirm before mounting :-)
Thanks! |
| 82spider |
A simple yes or no would be fine....
Thanks. |
| makey2 |
| ur lcd should be upside down and facing the bulb, it gets mirrored and inverted by the lens. (unless ur using a mirror) |
| 82spider |
| THANKS YOU! Just wanted to confirm with someone |
