| lndm |
10A at 110VAC? That would be 1.1kW RMS :hot:
I like the idea for fuse access, maybe you could put a lower rated fuse in there. |
| phn |
If you think the fuse is a problem, then it probably is. Otherwise, no.
I like the fused version. I believe the fuse on the transformer secondary is more important, but like one on the primary as well. (I'm a safety first guy.) And I think Indm is right. I believe mine are 2.5A. |
| alizawi |
| A bunch of links referenced on this forum recommend using 5-6 A fuses on the primary end. I guess I can take out the 10 A one and replace it as suggested |
| BrianDonegan |
I think there is a little confusion. The fuse holder can handle *up to* 10A. I don't think the connector actually comes with any fuses.
Use the fused connector and the appropriate size fuse for your project. |
| RDL2004 |
Note last part of description: "Fuses sold separately". The receptical itself is rated for anything up to 10 amps.
These will work fine, however be aware that with the snap-in kind, your panel thickness and how accurately you cut the hole is very important. I prefer the screw mount type myself, the hole can be pretty sloppy and panel thickness is irrelevant.
- Rick |
| lgreen |
Rick is right, unless you are very good at cutting the square hole there is a good chance that the snap-in type will not be in there very securely.
In which case you will want to use the same type that is a screw-mount. Like Q201-ND (Fig. 1) at digikey. |
| alizawi |
| Good lookin out, I just read the info real fast, didn't notice the fuse wasn't include.....about the hole, i might get my holes done professionally, but if I do them myself i guess i'll stick with the other connector........ by the way, which switches are best...SPST, DPDT or any other kind? |
| alizawi |
| what do you guys think about the apex ones...looks like the best solution to me |
| DcibeL |
| If you like the power switch at the back of your amp then go for it. |
