diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Linkwitz LM4780 PCB Proposal: Comments Wanted! - Click HERE for Original Thread
dfdye
After building a set of LM3886 amps based on the Linkwitz circuit (which I really like!), I figured I would try an amp using the LM4780 based on the same circuit layout. Since I haven't used this chip before, I figured I would ask:
1) If anyone has used the Linkwitz circuit ( http://www.linkwitzlab.com/images/graphics/3886amp.gif ) using the LM4780 as two LM3886's. I know other amps (Brian and Peter's come to the front of my mind) use this chip in a similar manner, but I was specifically interested to see if anyone has used the Linkwitz topology. It should be fine, but there is no since in re-inventing the wheel if there is someone who has already found out any issues. (Searching the forum didn’t show much, but I figured someone has to have done this!!!)
And 2) Attached is a proposed PCB that fell together rather nicely, but I figured I would run it past more experienced designers first. Particularly, I am concerned about the V+ section coming from the input pin header to C+ and the input signal traces running along the top right edge of the board. If anyone has any comments either way as to whether my concerns are justified, or if I am in good shape, I would appreciate the feedback. Any suggestions or comments about the rest of the board are welcomed as well!
Thanks!
David
As a side note, I started off trying to make this a single sided PCB. That idea got trashed rather quickly, but I was wondering if anyone has used a single sided LM4780 PCB?
dfdye
Well, I hope nobody finds anything! I just dropped in a prototype order (with a bunch of other stuff too . . . ) so I guess we will see how it comes out!
David
morgandc
just letting you know that someone is reading your thread with interest...
-Dwight
jackinnj
do you mean to use additional opamps, or use the LM4780 itself as one of the components in a filter network?
dfdye
quote:
I am not sure I understand you question. I am using the LM4780 as the amplifier, not a filter.
(If I misunderstand your question, please forgive the basics. . . .)
I am treating the LM4780 as two LM3886's. If any additional filtering is required, I will indeed use external components. I am currently planning on using these as part of a multichanel amp that will drive actively filtered speakers, so yes, I will be using additional opamps as a filter network, but I am not considering the LM3886's to be part of that filter network. The exception is if I use the two 220uf electrolytics in CGA/B instead of a 10uf film cap. This effectively filters most of the high end response if you are using these amps for woofers. This amp layout is pulled right from linkwitzlab.com, but I guess a copy of the schematic might be helpful. The Ci* cap does add a filtering, but again, that is not really the point of this circuit.
If this is not what you were asking, sorry for the tangent. :D
David
dfdye
quote:
-Dwight
Thanks! I'll let you know when I get the amps built and tested.
David
alexcd
Looks pretty good. I'm having a hard time keeping the output stable in a bridged configuration. Make sure you use small bypass caps very close to the chip and keep leads short and neat. Ballast resistors are required if you plan to bridge channels.
Upupa Epops
Rail lines are too slim, David. Image it in real size and imagine, that there should " flow " 10 A....
jackinnj
quote:
Using the overture series chips as part of an active filter has been tried -- not by me -- I haven't heard (or seen) any results published so I wonder if it is stable in this app.
dfdye
Ah, now your question makes more sense. I am not sure, but I have not tried it in that configuration.
David
lohk
... The exception is if I use the two 220uf electrolytics in CGA/B instead of a 10uf film cap. This effectively filters most of the high end response if you are using these amps for woofers.
How can you say that?
These caps form a hipass filter and do not filter the the high frequency response - no they tailor the lower frequency range for the midrange/tweeters if they have smaller values - it is all clear in the schematic drawing. The lopass filter - if you may call it like that - which tailors the high frequency response range is situated at the amps input.
lohk
Oops, I did not read clearly - sorry for misreading...
dfdye
quote:
Yea, I would generally agree with that. I was thinking I could get away with them because of the short runs, but I will definitely put a little more effort into beefing them up. The problem comes in with getting the power runs thick enough while getting them to all the Power pins. I really don't know enough about this chip to comfortably leave pins unconnected, but I agree getting full current to all pins should be a goal.
alexcd
After reconsidering, I think there are better PCB layouts for this chip that would allow it some more breathing room (current that is.) The schematic from Linkwitz does seem solid though.
cjd
I find routing power in from the left side to be most effective with this chip. I have a small PCB I've done (1.5"x3") and that includes room to mess with some of Carlos's tweaks, bigger caps at the chip (2200 on mine), and paralleled output. Would be exceedingly simple to modify for two discrete channels. I'm still working on transferring it to Eagle. Prototype I have runs gret - stable, quiet...
C
alexcd
CJD do you mind posting your PCB layout and schematic here?
dfdye
quote:
Second! I would love to see other people's ideas about this too!
David
dfdye
quote:
Along those lines, I also have a couple of board designs to take advantage of on board power regulation. I am not really happy with either of these yet, but I figured I would post them to let you guys have a look at my thinking. Keep in mind that they are still very rough drafts, but feel free to rip into them if you have suggestions!!!
I especially don't like having the input traces run past the V+ trace in rD, but if I put the input signals in front of the chip, I have to run them past a NC pin as in rE (also the traces are much messier in rE even thought the component layout is much cleaner). I am thinking about clipping the NC pins and running signals under the positions where those pads would go, but I haven't gone quite that far yet.
This is the rD board:
dfdye
here is rE.
md_Stryker
Rev E is a beautiful layout! Very symmetrical!
Sorry you had to go through several iterations, however you have come up with a winner!
dfdye
Well, I guess the proof is if it sounds good! I actually am having that one made in an olimex prototype board. I had some other stuff to made and needed to fill up a eurocard, and this one was the one I picked to throw in.
I guess we will see in a couple of weeks! :D
digi01
David,
the layout looks nice!
just 2 suggestion of double side pcb layout concept:
1,trying to isolated signal tracks and power supply tracks at different side,it can make all tracks short and clean.
2,set up the properties of polygon plate is remove dead copper.
Zang
Upupa Epops
David, isn't good to let all heavy devices ( PCB + elyts ) fit only by soldered pins of LM's... Remember also, that to PCB will be lead also heavy wires... Make there some fiting holes...
cjd
This has some resistors and connections to be used as half an X-GC (SuperSymmetry) if any of it seems confusing. The halves og the chip are paralleled here, but splitting it to be discrete channels would be simple.
C
dfdye
quote:
Absolutely! The problems I was running into was one of getting thick enough power traces without overlapping signal lines. I'll have to play with that a little and see if I can get everything in from the same side!
[edit] Oh, and the dead copper was supposed to act as shielding. I read somewhere (and I have no idea if it was credible) that as much copper coating the board as possible added to signal rejection. That may only have been if it was grounded, so I will try and find out if I am mis-remembering![/edit]
I completely agree about the devices being too heavy for just the chip pins. I can't believe I forgot to make mounting holes! As for the power, I was planning on using pinheaders and soldering power leads to those, but I think the direct wire method seems to have more suport, so from now on that will be what I will use for power.
Thanks for the suggestions!
hostname
hi, david
Can you share eagle file for rev E design?
P.S. Nice Work :cool:
Page generated in 0.060183048248291 seconds with 17 queries,
spending 0.00865436 doing MySQL queries and 0.05152869 doing PHP things.
