diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
equivilent part numbers for 6K35HF - Click HERE for Original Thread
vixr
does anyone know if hammond sells a transformer with the same spec as the Allied 6K35HF??? :confused:
Alain Dupont
vixr,
There are 2 similar models at hammond
* 166K6 6.3 VCT at 1.2 Amps Primary 117 volts
and * 226E6
but they are at 25 and 34 cad$ each so buy the Allied 6K35HF
at 7.44 U$ it's cheaper !!!
Alain.
vixr
Wow... That's pretty expensive... I was trying to save a few bucks on shipping by buying both transformers from the same vendor. The 269AX is in the 35 dollar range too...Thanks for the info.
Page generated in 0.018440008163452 seconds with 16 queries,
spending 0.00843239 doing MySQL queries and 0.01000762 doing PHP things.
