| richwalters |
I'm getting alot of trouble with internal flashovers using KT90 tubes in standard UL circuits in lieu of KT88's. . Anyone had sim experience ?
I'm running these tubes in parallel pairs UL-PP in a 35W guitar amp 265V B+ and constantly blowing B+ fuse. Swapping with KT88's is abs troublefree. Is there something about KT90's I should know about or missed ? It's often stated that this tube is a drop-in replacement for 88's and can take more B+. I daren't turn B+ up to 550V. I know the internal res of the KT90 is a touch lower, but I wonder if this tube is a born looser.
richj |
| Tweeker |
I've read that some runs of 'KT90s' have had qc issues, your particular tubes may be losers. Are you sure they are biased correctly etc etc.?
If a pair of KT88s work and you only need 35 watts, you might consider just sticking with them.
KT90s seem to be popular triode strapped, so I dont see why UL should be an issue. |
| maynardg |
| I have KT90s - older series 2, I think, running in PP UL at ~430V without problems - actually much nicer sound than KT88/6550's in this stereo amp. Couldn't be happier. |
| richwalters |
| quote: | Originally posted by Tweeker
Yeah, I know but I have a tempting high power switch eg, B+ at 530V and any tube not up to par.......ZAP. I do like to run MI to 175W per ch.
Biassing fine....80mA each quite modest at 265V and 55mA with 88's on high B+. well within specs and no sign of oscillation.
Clearly KT90 Qc looks suspect (yet again in my case) ....considering Manley used them en-masse in their amps. I will have to get mine rechecked and the truth known.
I've always considered KT90's as a "hard tube" electrically, that when driven into clipping as in MI, perhaps there is a more drastic impedance change perhaps a "latch-up" when compared to other tube classes ....OMO. I've never had these problems with the 88 class. ANy o/p tube should survive a slam drive test at full power, i.e square wave into hard clipping them flipped into sine wave without snags. I use a fuse in centre tap o/p tranny and to blow a 1A with quad KT90s is a sure warning signal. The power supply has more poke than a hospital defibrilator.... so respect is needed.
The tubes I find most consistent on power uppage and well tolerant is the JJ KT88's (a pity about the bulb style) ;in comparison theSvetlana KT88 is overpriced and gives lower poke.
richj |
| edl |
The later (during and after the NATO-bombing) manufactured Ei KT90's are made in poor quality.
Anyway I suggest to give JJ-KT77 a try. They giving 70W clean power in PP-AB, with low distortion and low power. Their price is good too.
BR, |
| richwalters |
| quote: | Originally posted by edl
BR, |
Aah...... shattered my confidence....you would say that.....irritated by the 90' problems I put in my reference set of KT88 GL replica by Tesla and by golly they deliver exactly what I'm after. But theyr'e not staying in... Thanks for KT77 tip....will check up B+.
richj |
| choky |
| quote: | Originally posted by richwalters
richj |
ask Jim McShane for KT90
I don't have exact URL,but little googlin' must be helpful
he was always source for reliable KT90
edit:
http://pages.prodigy.net/jimmcshane/ |
| burnedfingers |
| I have some EI brand KT90's and have used them in my Quicksilver mono block amps with no problems. |
| richwalters |
Interesting commentary and site but I detect not all is well with KT90 Qc for some time and remains hesitant.
Anyway I've shaken my vendor and they are willing to swap etc....
I've got a sneaking suspicion that some KT90's are also made in the F.East and rebranded.
Are there any recognisable etch code marks on a EI KT90, if so where would they be ?
richj |
| SY |
| One other possibility is that these really are rebranded sweep tubes, and the particular beam plate/screen really shouldn't be run over its (probable) 150-200V rating. |
| richwalters |
| quote: | Originally posted by SY
More injury to an opened wound...Implying..What tube have we got here with such low ratings ? With such a phantom sized anode, one of the biggest in it's class implying with it's mediocre performance it's hardly worth assembling the blighter in the first place. Coke B'le 807's would perform better and per se more reliably.
My vendor wouldn't risk playing foul with me, I did mention on my previous lot < no foul up's on these and check'm simmering at 500V> (that was 88's).... however there are vendors who would just sell a tube for a cheap buck and say it works and one gets a short lived ticket.. (We get fed up returning phony tubes in the post..)
I'm going out to shovel some snow......blue glowing anode (sky) overhead.
I know there are EH KT90 types around. The question becomes one OF which batch...? 7/10 bad... rest av..
It seems I might have to pay up/ settle for JJ 88's and be content.
richj |
| burnedfingers |
| Mine were personally brought back from Bosnia by a former resident. They were also tested at the factory and hand picked before they left the factory. |
| richwalters |
Quote <<ask Jim McShane for KT90>> I certainly did and replied <<avoid'em>>. Many thanks SY (you were right) and others who commentated.
KT90 for me is for claypigeon target:headshot:
richj |
| burnedfingers |
richj
I will set up a test jig and check some of my KT90's. Give me the voltages and I'll let her rip. |
| SY |
Put 150 volts on screen and plate. Do a sweep of gid voltage from, say, -50V on down, monitoring plate current to see if you've got a high perveance tube on your hands.
I understand rich's frustrations 100%, but it may well be a horses-for-courses situation where the tube could prove to be quite useful, just in a different circuit. |
| richwalters |
High perveance stuff.......Yes SY... quite right... It entered my mind...umm I honestly wouldn't recon my vendor would risk mucking me about with reflog line output stuff ...he knows I'm up in glass theory & MI & Hi Fi...unless his tester was pizzed drunk :cloud9: from weekend hangover.
Hitting the theory..The thought of grid blocking (bouncing of primary and sec electron emission from g1 can oppose grid current flow) can cause thyristor type latch up on certain tubes. I know it's mentioned somewhere in Langford Smith's book.
:joker:Ok....If the Jester sold me high perveance rebranded clown KT90's...line output apps wouldn't showup the problem I'm up against. That I'm pretty certain.
but as the grid leak in my amp circuits is 68K and driven from a slam low Z source, the remainder of the amp works pristine with KT88's right up to 40KHz....... the Ei KT90 data mentions direct substitute for KT88 and so on.....so what have
we got here ?
The conditions (quite normal).. 530V B+ UL43% (g2 knat's xck lower) via 220R carbon and quies set at 60mA. This implies g1 at approx -68V.... obviously peak signal swing around that figure.
However, as SY points out, checking at lower electrode voltages, there is the crossover characteristic with neg load lines. I've got a seeking suspicion we may have discovered the problem.
Uncovered a massive crummy manufacturing scandal ?
Any more revelations from the pit ?
richj |
| icarex69 |
...or lack thereof!
I bought 3 "match quads" of these from a vendor who recommended them over EH he also sold.
When I tested them they looked like they had just been selected at random!
Worse....using all 12 tubes I could not make one reasonably close quad...the best I could manage was two sort of OK pair!
Not counting 2 were duds right out of the box.
Of the working ten the weakest passed 78mA in my tester and the strongest just over 150mA....you could hardly believe they were even the same tube.
After 100 hours of use those two OK pair had drifted apart so far I had to go back to the others to make up a reasonable match again!
I've just had a similar experience with 2 so called matched quads of Chinese KT88s.
I've finally come to the conclusion that NOS tubes aren't overpriced after all because every modern power tube I have ever tried has had poor consistency.
John Corneille |
| richwalters |
oh yeah....I've also returned several KT90 octet sets to my vendor....there seems alot of duff ones going around.....reselling duff ones? I wonder what's going on behind our backs....
I know the pmcomponents group UK were thinking of a re-interest in KT90 production i.e drastically sorting the tube and it's problems out. I haven't communicated with the company for some time (last year) so I don't know what the up-to-date is.
I'm quite sure there would be a good market for KT90's if somebody could get them to work right. It remains a mystery as the tooling was Philips which was very reliable. It can't have all been bombed by NATO ?
richj. |
| burnedfingers |
It was hard getting a close match for two matched pairs out of the 5 pairs I own. Being able to set individual bias for each tube was the saving factor. Ran them in the Quicksilvers again with 485
VDC on the plate and 55mA each for bias with absolutely no problems. |
| kt88music |
| quote: | Originally posted by burnedfingers
Those Ei Kt90. Are they any good to sub my JJ KT88? |
| kevinkr |
The KT90 is a bit of an oddball, originally this tube was designed in the late 1980's in conjunction with David Manley of VTL fame. The first samples I ever saw in fact were VTL branded, laters ones were just plain EI. I ran them at up to 600V in UL with relatively "few" problems.
Note that the KT90 plate structure is borrowed from one of the big EI sweep tubes, they were quite open about this at the time, what else they borrowed I don't know. I do remember the screen grid voltage rating was not far removed from the plate rating.
Edit: I also seem to recall that the curves for this tube were not kinkless under certain conditions - I never encountered a problem with this, but allegedly this is not the most linear output tube in the class.
QC was a bit of a problem right from the get go, the most consistent ones I have ever seen were the ones built early on for VTL, the later ones were considerably less consistent. I did have one (VTL branded) literally explode in my hot rodded Citation II which scared the **** out of me! :hot:
I thought good KT90 sounded better in that amplifier than JJ KT88 or even vintage used GEC KT88. I think Trombone here on Diyaudio is still using KT90 in his modified Citation II which is based on my design. You might want to give him a ping for his opinion. |
