diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Looking for a PCB for bridged LM3886 - Click HERE for Original Thread
zafira1981
hi!!! I'm looking for a 2xlm3886 parallel PCB. Anyone sells a kit?
thanks
dfdye
I think Rod Elliot has something like that.
Try http://sound.westhost.com/project19.htm but it uses the LM3876. . .
If you are interested in a 2X LM3886 board, why not use a LM4780 board from http://www.audiosector.com You can get a full kit from Audiosector that has gotten several very good reviews from members of the board.
PS If you are looking to bridge them, the "dual core" LM4780 will have better thermal tracking between the amps allowing them to play better together. I would rather use this setup than two LM3886's due to this consideration.
Page generated in 0.018438100814819 seconds with 17 queries,
spending 0.00676537 doing MySQL queries and 0.01167274 doing PHP things.
