diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
double check the math - Click HERE for Original Thread
tenderland
Hello Im building the attached amp in a mono mode and the B+ will be
300 v instead of 350. to keep the preamp voltages and currents the same I calculated the the 27K feed resistor to be now 3333 ohms
Does this seem kosher ?
Thanks Jeff
arnoldc
The voltage difference then is 350-293 = 57V, with 27000 dropping resistor, the current is 2mA.
Now you want to drop 7V (300-293) at 2mA, the resistor is 3500 ohms.
Close.
richwalters
Use switchmode caps for cathode decoupling stages...they make a worthwhile improvement in sound quality. Choose 105°C low ESR types. Soundwise, I find them just as good a tants, esp for 1st stage.
richj
Giaime
quote:
richj
Do you really like tants? :xeye:
Page generated in 0.037434101104736 seconds with 17 queries,
spending 0.01951551 doing MySQL queries and 0.01791859 doing PHP things.
Please support our sponsor.
